Old 23rd June 2007, 00:00   #1
RRL
Garage: E39 M5 (future)
Dead pixels in temperature display an expensive fix?
I've been eyeing this car when I noticed an issue with the temp. display, dead pixels. Is this an expensive fix or an indication of other bigger problems?
Also, attached is the window sticker, I know PDC isn't installed, but what other options are missing?
Thanks in advance.
RRL is offline
Old 23rd June 2007, 00:22   #2
PJS
PJS's Avatar
Garage: 2003 M5 Sterling Gray Metallic
Sales Feedback: (3)
right off the top of my head... it does not have the M audio option...
not sure about the pixel problem... most pixel problems are on the dash display...
2003 M5
Sterling gray/black extended leather
Hardwired V1 with remote display, UUC SSK w/DSSR, Dinan Stage 3 software, Dinan exhaust, Dinan 3.45 diff., Dinan CAI, Dinan MAFS, Dinan front strut bar, Dinan rear sub frame reinforcement kit, Dinan rear sway bar with TCD brackets, 275's all around (powdercoated black)
2004 GT3
Black Fikse Profil 13s/Gold BBS E88, KWv3 coilovers, TRG susp. bits (toe links, control arms, monoballs, etc), Schroth 6pts, Recaro Profil SPG Xl seats, Speedware custom bar, Manthey CF wing and mirror housings, headlight armor yellow film, 4.0 Porsche Motorsports Ring and Pinion, custom ASP headers and exhaust
2007 F150
bed liner, exhaust
2004 X5 4.4
everything but sport package
PJS is offline
Old 23rd June 2007, 02:33   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
also have not seen pixels missing in the climate control pannel, only on the dash. (at least out of the three e39's i've owned!)
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 23rd June 2007, 04:29   #4
RRL
Yeah, I've always seen them on the dash too. The climate control is new.
Ok, so M-Audio is an option, and from what I've read, I'm not missing much considering the Bavarian Soundworks Alternative.
Ummm, rear airbags, was that an option too?
RRL is offline
Old 23rd June 2007, 07:26   #5
ard
ard's Avatar
Oh, you ARE using the search! Good catch.
Check this out:
http://www.realoem.com/bmw/showparts...78&hg=64&fg=20
Worst case $600 for a control??? (These prices are NOT CURRENT) Not sure, but maybe the faceplate/display is a separate part??
A
ard is offline
Old 23rd June 2007, 14:22   #6
RRL
Thanks! I've just been looking for the panel not realizing that I may have to replace the entire control. There's a company on eBay that fixes dead pixels but that's just for E36s.
I've used Search for an options list, but I also noticed options can differ depending on Luxury or Sport on the car. Maybe M-Audio is standard with either one, or airbags, or PDC or lord knows what. Just doing a sanity check.
Thanks!
RRL is offline
Old 23rd June 2007, 15:29   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Thanks!
M audio and PDC was an option no matter which version of the car you ordered. Rear sunshade was Sport option only (at least post '00).
Rear airbags standard '01 and '03 and a no cost option in '02. Since most dealers didn't catch the '02 change, not many cars were ordered that way.
gsfent is offline
Old 23rd June 2007, 16:02   #8
RRL
Does that mean for '02 rear airbags would be a line item on the options list?
RRL is offline
Old 23rd June 2007, 18:26   #9
ard
ard's Avatar
Should be.
Any dealer can pull the original order options from the VIN. It should be an ordered option in 2002.
A
ard is offline
Old 25th June 2007, 17:29   #10
RRL
Got an answer to my initial question about the dead pixels. The whole unit would have to be replaced to fix the pixel problem. That's going to be $1,600 if there are rear climate controls, or $700 for non-rear climate control equipped, that parts and about 1.5 hours for labor. OUCH!
Still thinking about buying the car though and living with the pixel problem.
RRL is offline
Valentine V1 Install w Remote Audio Adapter and Concealed Display - With Pic's! rlpM5 E60 M5 and E61 M5 Touring Discussion 69 1st April 2009 01:06
Missing Pixels on dashboard display Mike Krieger E39 M5 and E52 Z8 Discussion 122 25th October 2008 22:57
Dead pixels - dashboard display Michael_s E39 M5 and E52 Z8 Discussion 26 13th April 2006 05:19
display pixels shimmy E39 M5 and E52 Z8 Discussion 42 9th May 2005 17:21
M5 head-up display Christian_Fog E60 M5 and E61 M5 Touring Discussion 27 10th July 2004 01:47
Page generated in 0.14894 seconds with 11 queries
