Old 19th June 2007, 23:36   #1
Norcal M5
Garage: ///Oxford green/Caramel/Walnut
OBD "Communications Failure" during CA Smog Test
The techs at the ARCO Smog pros started looking at my fuse box during the smog inspection this morning, which seemed odd. Later, I found out why. They suspected a blown fuse because they got an error during a test. On the form, the "fail" was under a test called "malfunction indicator light." The verbal explanation by the tech was; no output at the OBD connector. The notes say "this vehicle failed the MIL/Check Engine Light due to OBD communications failure."
Is anyone familiar with this? The SES light is not on. I would check the volts at the OBD pins, but I can't read any pin numbers and wouldn't know which ones to check. Any advice?
Norcal M5
Norcal M5 is offline
Old 19th June 2007, 23:48   #2
pedorro
pedorro's Avatar
Garage: 2002 M5, LeMans Blue/Caramel
Your firmware needs to be updated by the dealer as there is a known recall. I had the same problem with my 2002 when I purchased it in December.
pedorro is offline
Old 20th June 2007, 00:01   #3
Vossen10
Vossen10's Avatar
Garage: M5
+1 on the update, dealer will do it in a few hours at most. FYI: if you have performance software, be mindful as i had to have my Dinan software re-flashed after the emissions software update. The update simply allows your car to communicate with a new computer system the emissions guys are using. no big deal really... also, lots of prior discussion on this topic can be found in the archives.
Dinan M5
335i Coupe
Vossen10 is offline
Old 20th June 2007, 00:55   #4
Norcal M5
Thanks, Vossen. So, you're saying the dealership is going to charge for this, as opposed to the (best) scenario Pedorro poses where it's a recall?
BTW, in the archives I found an exact thread (by Webb12 on 7/13/04) but there was no resolution.
Norcal
Old 20th June 2007, 01:23   #5
Vossen10
Vossen10's Avatar
Garage: M5
Pedorro is exactly right, its a recall, it should definitely be free. Dinan also re-flashed my software free of charge. Thread you found seems a bit old, as I believe this was a mid-2006 recall. Let me see what i can find.
Edit: Found the thread. This should answer your questions... also includes the original letter BMW sent out to owners. Hope it helps!
BMW Emissions Recall
Dinan M5
335i Coupe
Vossen10 is offline
Old 20th June 2007, 01:55   #6
pedorro
pedorro's Avatar
Norcal M5
Here's the entry from my service vehicle history for the ODB update:
"SIB 12 11 06 - Recall - 06E-A03 DME Programming for ODB Communication"
Hope this helps.
Lee
pedorro is offline
Old 20th June 2007, 01:57   #7
abigfire
abigfire's Avatar
Garage: M5 in Silverstone
Yes it is a recall. I just had it done to my beast about a month ago. No charge. You should call for an appointment. The dealer I went to had about a month wait list to do it..... more like a month for a open spot when they're not busy making $$$ on the garage space.
Dan
'01 Silverstone
UUC EVO3 w/DSSR!
abigfire is offline
Old 20th June 2007, 02:01   #8
Norcal M5
Ah, very good! Thanks, Vossen!
Norcal
Old 20th June 2007, 02:28   #9
Norcal M5
Lee - yes. Big help. Much thanks! You guys were great.
I just got off the line with the dealer and will get the update in time to go in for my free retest at SMOG Pros.
Edit: Dinan also confirmed that they will re-flash for free.
Norcal
Autocar: M5 beats Ferrari F430 Just_me E60 M5 and E61 M5 Touring Discussion 204 10th October 2007 17:24
Troubleshooting faulty IATS installation? cosioboy E39 M5 and E52 Z8 Discussion 57 16th July 2007 03:56
California Smog Test. Buying out of state birdie74 E39 M5 and E52 Z8 Discussion 10 13th February 2006 05:40
Failed smog test from no communication with OBDII connector any ideas? lwebb12 E39 M5 and E52 Z8 Discussion 26 13th January 2006 17:46
barely passed CA smog sevenoftoine E39 M5 and E52 Z8 Discussion 6 26th October 2004 03:57
Page generated in 0.12694 seconds with 11 queries
