Old 19th June 2007, 21:59   #1
RickM5X3
RickM5X3's Avatar
Garage: M5 - Bluewater
Aggressive maintenance schedule -does it make sense?
I've got 42,000 miles on my 2002 M5 and plan on keeping it for its full lifecycle. I'm planning on having my dealer (who has a relatively reasonable service fee rate) complete the following tomorrow:
plugs (never done previously)
diff fluid (done at initial 1,200 miles)
gearbox oil (never done previously)
brake fluid (done 2 years ago)
Keeping in mind my long term goal, am I being too aggressive on any of these items? Anything else I should complete or keep an eye on for long term ownership? Coolant was done two years ago and I complete the oil service approximately every 5K. Thanks.
Rick
2002 Bluewater/Caramel
RickM5X3 is offline
Old 19th June 2007, 22:15   #2
Fuddy
Fuddy's Avatar
Garage: Silver E39 M5
I think that's just right
while you're at it, might as well do the coolant also
Fuddy is offline
Old 19th June 2007, 22:24   #3
gobuffs
gobuffs's Avatar
Garage: Chiaretto Red 02 M5
Per BMW:
brakes every 2 years
coolant every 3 years
plugs 100k miles
diff lifetime
tranny lifetime
oil 15k miles
I'll agree withe the brakes and coolant, but really disagree with the plugs and fluids. I'll go up to 10k on a good synthetic oil. Probablt 30k on the tranny and diff fluids. I have a set of plugs to go in but haven't done it yet (36k miles). I also recently replaced my fuel filter, MAFs, air and cabin filters, and all 4 O2 sensors.
gobuffs is offline
Old 19th June 2007, 23:23   #4
Kin Mak
Kin Mak's Avatar
Garage: BMW E46 M3
Sales Feedback: (3)
Send a message via MSN to Kin Mak
MAFs will be on it's way out and you might as well get the O2 sensors done as they are cheap.
Getting bushes replaced will transform the handling as well.
BMW E46 M3 SMG Carbon Black/Cinnamon
BMW E39 M5 Avus Blue - SOLD
KinMak.com - Loads of Photos - Elara Online
Kin Mak is offline
Old 19th June 2007, 23:59   #5
exigtis4m5(?)
exigtis4m5(?)'s Avatar
Garage: LMB 2002 M5
Sales Feedback: (5)
I thought Inspection II had Diff and tranny fluid replacment as part of it? no?
exigtis4m5(?) is offline
Old 20th June 2007, 00:09   #6
DRM
DRM's Avatar
Garage: 2002 M5 (Chiaretto Red Metallic)
Nope.....
No. BMW says they're good for "lifetime". What a joke.
Dan
______________________________________________
Daily Driver
'02 M5 (Chiaretto Red Metallic w/black napa full heritage leather/wood trim/leather Euro cntr console/BSW speakers and sub) Sig series Dinan S/C'd S3 package/ Dinan S3 clutch-flywheel/Dinan high capacity oil cooler /Dinan forged aluminum wheels/Dinan SSK/Dinan - Brembo BBK/Stg 3 Dinan - JRZ suspension/monoballs/275-35-18 RA 1's all around
The "Predator"
'02 996TT w/X50 (slate grey metallic w/full natural grey leather, small carbon package, aluminum trim pieces, exterior color painted wheels, etc, etc).
EVOMS Stage 4 (640hp/615tq)
PSS9 w/F&R H&R sways and EVOMS F&R shock tower braces
Sachs clutch and Porsche SSK
Toyo RA-1's 245/18 fronts; 305/18 rears
DRM is offline
Old 20th June 2007, 07:29   #7
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
Diff and tranny fluids are good for 30,000 miles in my book if you plan to keep your beast.
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Old 21st June 2007, 02:50   #8
RickM5X3
RickM5X3's Avatar
Got 335 . . . .
Thanks for the advice. In the process of checking things over, the dealer has started a Puma case on the catalytic converters and kept the car.
I have a 335 loaner and it seems significantly stronger than my M5 has ever run. Maybe that analysis would change at triple digit speeds, but I am shocked at how ridiculously strong that bi-turbo is here at altitude.
RickM5X3 is offline
Old 21st June 2007, 03:00   #9
M5CCIE
M5CCIE's Avatar
Sales Feedback: (5)
That's funny. I have my M5 into Murray for a few things and they gave me a 335 loaner as well. That car is sick fast. TC cars are immune to altitude...our NA engines take a 20-25% hit in performance.
BTW, if interested...:
Gustav US Tour - Denver, CO [Aug 5/6]
Bluetooth
V1
Aux port
M5CCIE is offline
Old 21st June 2007, 03:01   #10
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Originally Posted by gobuffs View Post
Per BMW:
plugs 100k miles
diff lifetime
tranny lifetime
oil 15k miles
on the M5 plugs are part of inspection 2, on a normal bmw plugs are 100k items. I felt quite a difference when i replaced my plugs at 57k miles for the first time, i felt no difference when i replaced them recently with 16k on them, so somewhere in between is a good interval for me! I'm thinking every 30-40k for plugs.
Diff and gear box every 30k would probably be good. Personally, for the past 3 years, i'd had the diff and box lube changed yearly, just at the beginning of winter, and must say it makes for a much nicer shifting gearbox in my car.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Maintenance Schedule? Redstradic E60 M5 and E61 M5 Touring Discussion 6 7th July 2007 19:10
Does it ever make sense to lease a used car? greer E39 M5 and E52 Z8 Discussion 23 6th February 2005 21:47
Thank you V1 AND 11-99 . . . (Wait, does that make sense?) khiroshima E39 M5 and E52 Z8 Discussion 6 18th March 2004 00:58
These waitlists and $$$ over MSRP don't make sense to me. ALittleLuck E39 M5 and E52 Z8 Discussion 2 10th September 2001 17:55
Page generated in 0.16369 seconds with 11 queries
