i've done this a few ways. I've had one of those pressure bleeders, essentially, a small garden sprayer, put a liter or two of brake fluid in it, attatch it's cap to the master cyl, pump it up to about 10psi, and crack open bleeder valves until clean fluid flows.
To "finish" the job, i'd have my 10 year old son give a push or two of the brake pedal as i opened and closed the bleeder valve.
More recently, i picked up a vacuum type suction bleeder, that runs off the air compressor, i still ususally finish with a couple pumps of the pedal by my son.
I also do empty and refil the master first with fresh fluid. You could do either as a one man job without the pedal pushing at the end, and probably have good results, but the pedal pump at the end makes me feel more complete.
I do think you are leaving old fluid in the dsc/abs system with any manual bleed (not certain though). So an occasional dealer flush where they cycle the dsc/abs pumps may not be a bad idea.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
