Old 27th May 2007, 19:36   #1
Pwdrhead1711
Pwdrhead1711's Avatar
Garage: 2000 M5
Hopefully, some helpful info... [resolving low end hesitation and poor idle quality]
I recently had some performance issues with my car and I thought I would post the experience on the board. It's a kind of return the favor thing, as I would have never been able to find the problem without it and it's memebers.
I have been experiencing some serious low end hesitation and poor idle quality, in the last month or so. The SES light was on and off on occassion. I took the car in to Bavarian Hypersports to get an Eisenmann exhaust, SS X-Pipe, SC program, underdrive pulley's and Strut Tower bar put on so I had Joel pull diagnostic codes at the same time. I had my local mechanic pull codes prior and we got similar results. Cam position sensor and Vanos Inlet pressure. I had been reading forums and brought up the MAF sensors but Joel thought I was looney. I had Bavarian replace the Cam position sensor and clear codes. The performance seemed a little better, but SES again. This time had my local mechanic pull code and it was 170 Secondary Air Quantity Low. Since, my Ebay ordered MAF's were stuck in customs I went to VW and dropped a couple of bills for MAFS w/ part#'s found on this board. Installed them cleared codes, and Holly S**t, my girl was back!!!! What a beast she is again. I'm changing these bad boys with every oil change now...
Chris
Pwdrhead1711 is offline
Old 28th May 2007, 04:12   #2
vev78
Garage: 2000 M5 carbon Black
I had the same problem with my MAFS. New Mafs every 5000 miles is a bit much isn't it? How often are the MAFS being changed?
2000 M5 Carbon Black, Black with blue inserts,BB Tri Flow, UUC Short Shifter, Dice ipod, Ceramic Tint, Hardwire V1
1967 GTO HO coupe
4spd, Tri Power, 355 Posi,pwr windows,pwr disc brakes,hood tach.
1998 Yamaha VMAX 1200 "The Other Beast"
vev78 is offline
Old 28th May 2007, 16:13   #3
Pwdrhead1711
Garage: 2000 M5
It's only money. I spent $2,500.00 on an exhaust to pick up a couple of HP what's $150.00 on ebay to make sure I keep it.
Old 28th May 2007, 18:12   #4
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
While MAF's may be semi consumables (and VW replacements pretty inexpensive), they should last more than 5000 miles. I have the same MAF's for at least 45000 miles (my ownership of the vehicle) and no issues (and I hope my car can't read this to make me a liar! )
No indication of mileage on yours, but see how long these new MAF's last before just changing out. Stock intake or K&N?
gsfent is online now
Old 28th May 2007, 18:56   #5
ard
ard's Avatar
I'll take those old mafs you're throwing away...
I can recommend changing air filter elements much more frequently that BMW intervals- every other oil change, or even with every oil change, is not inappropriate.
A
ard is offline
Page generated in 0.11142 seconds with 10 queries
