Old 22nd May 2007, 00:50   #1
Tenzin
Garage: Blue '03 M5
Hand Pump Oil Extractor?
http://www.skymall.com/shopping/deta...152387&c=10130
I've been travelling for work, and saw this item featured in the Sky Mall magazine on one of the flights. Anybody use this, or anything similar to it?
Tenzin is offline
Old 22nd May 2007, 00:52   #2
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
ive used one before, very simple. the pipe went down my oil gauge and i pumped the oil out. i didnt like it much due to the pumping and im old school. so i went back to getting under the car for an oil change.
razahyde is offline
Old 22nd May 2007, 02:11   #3
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
That's exactly the one I use, made by Pela. Wouldn't be without it...
BKH is offline
Old 22nd May 2007, 05:17   #4
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Great concept, BUT and there is always a but! Contaminants/debris within the motor usually collect at the bottom of the oil pan near the bolt. When oil is changed (the old fashioned way) by removing the oil pan bolt the contaminants and debris gets drained along with the old oil. Does not happen when using the dipstick pump.
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 22nd May 2007, 06:01   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i have this too. It looks identical to the one from griots garage, i bought mine from something like www.mytoolshop.com (some variance of that url). I will admit never using it on the M5, i too like to get under the car to poke around.
On my 528, i used it regularly, griots catolog says various tests were done and it was pretty effective at getting all of the old oil out. I did a little test myself, drained it with the pump, then pulled the drain plug and there was essentially a few drops that come out.
If you, like many people, probably do not have the car level when you do the jack and drain method thru the drain plug, you're probably leaving more in the pan than you would with a topside extractor.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 22nd May 2007, 08:24   #6
Tenzin
Garage: Blue '03 M5
I do indeed have a concern about not getting a full drain, as well as having some debris collect near the plug. That said, doing it myself wouldn't involve a lift, so agreed I'd be leaving stuff in the pan still as well.
Thanks for your thoughts folks.
Tenzin is offline
Old 22nd May 2007, 18:29   #7
Hawkwind
Hawkwind's Avatar
Garage: 2003 M5 Sterling Gray
If you want to get every last drop, why not jack it up to get the pan under there and pull the plug, then jack it back down so it's level until it has drained, then jack it up again?
Not that it's worth the effort, but there are 2 ways to level the car - either in the air or on the ground.
Hawkwind is offline
Old 22nd May 2007, 18:44   #8
Tenzin
Garage: Blue '03 M5
Brilliant.
Tenzin is offline
Old 22nd May 2007, 19:22   #9
jclyman
jclyman's Avatar
FYI ... I found a driveway (my neighbor's across the street) where I can park the car in a level position, strattling the sidewalk ... the drive slopes down to their house, and of course on the other side of the sidewalk, down toward the street. Then I can reach everything without ramps or a rack ... enough room to move around underneath and all ... It was much easier than using my floor jack and jack stands ...
- Daniel Boorstin
jclyman is offline
Old 22nd May 2007, 20:00   #10
mottati
mottati's Avatar
just make sure you have a shallow oil drain pan! I did this and made a mess as the car crushed the oil drain container, it was too tall to sit under the car.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
My first DIY Oil Change billrM5 E39 M5 and E52 Z8 Discussion 43 11th January 2008 03:01
BMW Revises E60 M5 oil service procedure SuperBMW E60 M5 and E61 M5 Touring Discussion 9 3rd March 2006 00:17
Dipstick question unfoundhorsepower E60 M5 and E61 M5 Touring Discussion 7 11th February 2006 18:37
Naka's DIY oil change M-Fünf Most Memorable Threads' 43 28th July 2005 19:13
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.24799 seconds with 11 queries
