My car bogging with ses on - The Unofficial BMW M5 Messageboard (m5board.com)
Old 18th May 2007, 03:30   #1
kirbanana
kirbanana's Avatar
Garage: E39 M5 Alpine White
this has been going on for quite some time now but its on and off but this time when the ses light goes on, my car struggles to go through revs and it almost seem like it has no power at all. i haven't had the codes checked yet but aside from the obvious MAFs (which i've replaced about twom months ago, o2 sensor), what could it be? i just replaced my spark plugs a week ago....help please...ty
kirbanana is offline   Reply With Quote
Old 18th May 2007, 04:15   #2
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Fuel filter?, CPS?
Dinan Cans
Dinan Software
Beamer_usa is offline   Reply With Quote
Old 18th May 2007, 04:46   #3
ssomed
ssomed's Avatar
Garage: 2000 M5, lemans blue
codes please
see if you can get someone to read the codes. Reset them, and see if you get any that turn up consistently, and post them. I am having a similar problem, but cant seem to get the same fault code to repeat.
good luck,
ssomed
ssomed is offline   Reply With Quote
Old 19th May 2007, 23:09   #4
kirbanana
kirbanana's Avatar
its really strange. it comes and goes. right now the ses light is off but who knows when it turns back on again. one thing i checked was my oil level and it was half level on the stick. i added 1 liter of 10w60 to it and it seem to have made the car run a bit better. previous work done: new VW MAF and spark plugs. any relations to that? also, i was wondering if the dealership would check my codes for me for free? or is that a stupid question....
Old 20th May 2007, 00:02   #5
ard
Super Moderator
ard's Avatar
Are you kidding me?!
There are hundreds of possible codes and you're posting idle speculation and adding a quart of oil????
Buy a code reader to take it into the dealer. They WILL charge you- about as much as a Peake reader will cost.
Or take it to a autozone type place, maybe they'll read codes for free.
Post back when you have codes...
A
PS Hint to all- write down codes when you get them. Double hint- if under warranty DO NOT erase codes.
Old 20th May 2007, 03:10   #6
kirbanana
kirbanana's Avatar
i guess its pretty stupid to post without checking the code first right....i just wondered if running with low oil level for a prolonged period of time could cause problems to trigger the ses light (oil starvation to like maybe the vanos unit or something else.....)....i guess i'll check the code and take it from there.....
Old 20th May 2007, 04:19   #7
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #24 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (4)
My off the wall guess is that you are experiencing episodes of 'limp mode' which can occur without warning. But do check the codes as A. suggests to find the root cause(s).
2003 Jet Black lllM5 Dinan S3 #24
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger, Speedhut Custom Boost Gauge (Thanks, Steve), S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils and Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Ground Control Coil-Over Suspension, 430 7" F & 325 10" R, Dinan/Brembo Brakes, Zionesville Radiator, Spal 2-speed Electric Fan, AGA Power Steering Reservoir, Rennline Pedal Set w/ throttle heel/toe ext, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Sub-frame Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Drags: Nitto NT-555R Drag Radials 285/35R-18; Street: Michelin Pilot Sport PS2 275/35ZR-18; Laser Interceptor, Dual Head, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, BSW Speakers with iPod integration, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder. To Be Installed: PLX Kiwi WIFI Gauges With Rev2 & iPod Touch.
1/4 mile: 11.795 @122.20 mph, 60' - 1.819 03/11/2008 ATCO
Kelster is offline   Reply With Quote
2000 BMW M5 Misfires - And Dealing with Dealer & BMW NA on CPO HELP!!!!!!!!!!!! sean_w_smith E39 M5 and E52 Z8 Discussion 16 12th September 2005 16:48
Guess the World's most outrageous car ever Black M5 E39 M5 and E52 Z8 Discussion 43 19th February 2005 16:19
Stay away from RMS because Osh is a conman !! Black M5 E39 M5 and E52 Z8 Discussion 245 12th June 2004 20:53
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
Major Problem - Need Valuable Input! gra8fuldd ed Off Topic Forum 6 19th November 2002 09:38
