What is the DM-TL module, mine is broke? - BMW M5 Forum and M6 Forums
Old 14th May 2007, 02:57   #1
the-dragonfly
the-dragonfly's Avatar
Garage: 2002 M5 Electric Blue two tone, two ton
Using peake code reader on my 2002 M5, and cannot figure out what this module is and how it could be leaking.
Any help would be appreciated.
the-dragonfly is offline   Reply With Quote
Old 14th May 2007, 03:34   #2
No Frills
No Frills's Avatar
Garage: M
Fuel detection leak module. Could it be you refueled with the ignition on? That could trigger the fault.
No Frills is offline   Reply With Quote
Old 15th May 2007, 02:59   #3
the-dragonfly
I reset the codes, and they come back without any refueling inbetween. Maybe I will call BMA and inquire if there is a sensor or module that could be the source of the issue. Key is out of the ignition when I refuel.
Finally an answer thanks!
Old 16th May 2007, 02:53   #4
No Frills
No Frills's Avatar
Garage: M
Do you remember the fault code #? The DMTL pump/module may have crapped out. If so, change it soon. I dont know if it will has any effect to the rest of the fuel system.
Old 16th May 2007, 04:41   #5
the-dragonfly
Peake tools gave three codes for the table #18
2002 M5 with 90k on it. So far I have done sparkplugs, cabin filters, Air filter, Engine Oil and filter, Tranny fluid and Diff fluid. Next will most likely be to clean the MAF, change the valve cover gaskets, and fuel filter.
Peake Tool said
18,
Ab Secondary Air system- Valve sticking
7F DM-TL Module
28 After Cat O2 Heater Control cyl#5-8
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 15:43
Current Production Alan A E39 M5 and E52 Z8 Discussion 78 6th April 2001 06:01
