Old 12th May 2007, 20:48   #1
ZJamaican
Garage: Black 97 528i
Installing Entire Fog Light Assemply With Rings DIY? or Pro. Install?
I have a 97 528i currently in the body shop because of a frontal collision. The body shop agreed to order an M5 bumper instead of the stock one but they had me order the round M5 fog light assembly plus rings. I should get the car back on Monday but I won’t receive the fog light assembly plus rings until after.
Questions:
1. Will I be able to install the entire M5 fog light assembly plus fog light rings by myself without removing the bumper? If this is possible a few quick tips would really help.
2. I could take the car back to the shop and have them install it for free but the car is late by 2 weeks and I am fed-up with their service and lies to me, I’m worried they will take long to install the fog lights and I just don’t want to deal with them again.
Thanks for your help.
ZJamaican is offline
Old 12th May 2007, 21:21   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
easy to do, only two 8mm (or maybe 6mm) bolts, iirc to hold the fog lamps in. Must be a write up, if you have no luck searching here, try bmwtips.com
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th May 2007, 21:30   #3
ZJamaican
I've searched the forums here and checked BMWTips write-ups with no luck. So are you saying that I will not have to remove the bumper? I can easily install them from the front of the car?
Old 12th May 2007, 22:01   #4
mottati
mottati's Avatar
as long as the body shop leaves the wiring for the lamps accesable, you can install the fog lamps from the front. In fact, the few time's i;'ve removed my bumper (a 10 min job, max, by the way) i removed the fogs first, to get those wires out of the way.
http://www.realoem.com/bmw/showparts...17&hg=63&fg=15
Looking at the realoem diagram, it looks like there's only one small bolt that holds it in.
edit: do a search for hid fogs or hid fog lamps, i ran a quick search with hid fogs and there are a couple dozen posts about adding xenon bulbs for the fog lamps, someone must have done a write up, which would include removal and reinstallation of the fog lamps. Or check with board sponsor umnitza who sells them,
mottati is offline
Old 12th May 2007, 22:40   #5
Laidback
Garage: Camaro lol:)
Sales Feedback: (25)
+1...I have replaced foglights and wired an hid kit without removing the front bumper a couple of times...the trick is getting the black rings out ( which is easy as you just press the inside of the black rings and pulling it out )...goodluck
"Illegitimus non carborundum"
Laidback is offline
How many M5 owners to change a light bulb? Aussie2U Off Topic Forum 36 29th November 2009 22:54
HID Fog Light Questions...Help! ATLANTA M5 E39 M5 and E52 Z8 Discussion 10 28th February 2007 06:33
E65 HID Fog Lights Installation Guide umnitza E39 M5 and E52 Z8 Discussion 0 1st January 2007 23:59
Need Help from my M5 buds for the Mini group. MarkM5Lauderdale Off Topic Forum 15 17th November 2002 21:54
Page generated in 0.12113 seconds with 11 queries
