Old 26th September 2000, 14:37   #1
ALX
ALX's Avatar
Garage: 2007 X3 Sterling Grey Metallic
Send a message via AIM to ALX Send a message via Yahoo to ALX
Tree Sap on hood
Hello All,
I was wondering if anyone could suggest a cleaner to remove some crusted tree sap without damaging my M5's finish/paint. So far, I've used Goo Gone (citrus cleaner) to remove the majority of the sticky goop of the sap. But as I've said before, now all that remains is a hard crust that Goo Gone will not remove.
Any ideas?
Thanks,
ALX
ALX is offline
Old 26th September 2000, 15:37   #2
MarkM5Lauderdale
MarkM5Lauderdale's Avatar
Garage: 2002 Mini Cooper S
Post
Find a paint shop in your area with a good reccomendation. Have them look at it before you go any further. You may already be too late. Tree sap should be removed as soon as you see it. Letting it solidify is bad news.
MarkM5Lauderdale is offline
Old 26th September 2000, 19:14   #3
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
Post
you might be able to use a tiny drop of gasoline- apply a tiny drop of gas to a cloth and then try to gently rub out the sap on the hood. no matter what happens you want to immediately afterwards wash the car. then I suggest you at least wax the hood. this worked for me a long time ago on a honda so I dont know if it will work with the newer bmw paints. a suggestion before you try this is to call your dealer.
ME
MEnthusiast is offline
Old 27th September 2000, 03:57   #4
as
Post
I have found a 50/50 mix of warm water charcoal lighter fluid is very good. Be sure to wax the car after but please check with the body shop first
as is offline
Old 27th September 2000, 04:15   #5
1C00lVC
1C00lVC's Avatar
Garage: '01 Ti/silver E39 M5
Send a message via AIM to 1C00lVC Send a message via Yahoo to 1C00lVC Send a message via Skype™ to 1C00lVC
Post
Here is what I do: I put a good dab of liquid wax on the drops of sap. If the drops are fresh, it will disolve them in 10 or 15 minutes. If the sap hardend, if may take over night to soften it.
I use a cheap wax, just smell it to make sure it is petrolium based. It will have a "Flamable" warning label on the container..
I had a number of cars over the years, and typically the stuff came off with no trace. Now I have an Audi (to be replaced by the long awaiting M5), and the sap actually left a mark in the clearcoat which can not be buffed out..
A
1C00lVC is offline
Old 27th September 2000, 08:19   #6
ALX
ALX's Avatar
Post
Could you recommend some brands? Regardless, I will also check with my dealer's body shop.
Thanks to all who responded!
ALX
ALX is offline
QUESTION: What's the purpose of the under hood carpet/insulation ? .............. FAST 5 E39 M5 and E52 Z8 Discussion 17 2nd March 2003 04:36
CF hood - in a case of collision??? WarpSpeeD E39 M5 and E52 Z8 Discussion 20 12th February 2003 07:50
tree sap + cold weather = ??? kevin034 Off Topic Forum 0 29th October 2002 16:13
Looking to buy an E39 hood for cheap for a custom BMW MuttWidebodyE36 E39 M5 and E52 Z8 Discussion 0 18th September 2002 03:53
How to remove tree sap? greg E39 M5 and E52 Z8 Discussion 6 27th May 2000 23:46
Page generated in 0.11654 seconds with 11 queries
