Thrust Arm Bushing-Can you visibly see cracks/wear?
I'm getting some unusual cupping in the front left out edge tire. I'm not getting any clunking or trammeling. I also just had a PSS9 installed a few months ago (cupping occured b/f install). Was wondering if it were possible to detect wear/cracking from a visual inspection of bushing or do you have to just take a chance when replacing the bushing/arm hoping this solves the problem?
If it's on a lift it's pretty easy to inspect the thrust arm bushings with a good flashlight. Depending on how the wheel is turned you can see both sides of each bushing.
2007 Z4 M Coupe, Titanium Silver with Imola Red, black and silver interior -for details: www.mymcoupe.com
2003 M5, Imola Red with black and silver interior
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
2002 540iT, Sapphire Black with black and red interior
-Dinan stage 3 suspension with Koni shocks
-StopTech brakes
-255/40R18 PS2s f/r on 18x8.5 BBS RG-Rs
-Custom interior trim and seat massagers
-NavTv with DVD
I read people changing the oem bushing with X5 bushings...does anybody know where to buy them off the net? or there are any other bushing better than the X5 ones.
Its pretty much; OEM, OEM X5, Powerflex, or Dinan Monoball
Try braking fairly lightly around 50ish mph, slowly slowing yourself down. Then brake a little heavier on the next pass. If you can feel any wobbling in the wheel I believe that's a good warning the bushings aren't doing so well.
As for the X5 bushings, I believe the keyhole goes in opposite than the standard OEM 5 series bushing, but I may be wrong because I know very little about suspensions.
-StopTech brakes
-Seat massagers
-StopTech brakes
-NavTv with DVD
The other option is Vines arms off ebay. Some folks are getting significant miles on them with positive results. They have a heavy duty 4 wheel drive X5-style aftermarket bushing already pressed into complete arms with ball joints for about $130/pr.
Cupping is caused by the toe setting. Too much negative toe will cause out side cupping, too much positive toe will cause inside cupping. The thrust arm bushing will not cause tire cupping. A failed/failing thrust arm bushing will only cause vibrations. For it to have an impact on tire wear, the bushing would have to be so bad that you would get a clunking sound when braking. More than likely you have too much negative toe in. Most alignment shops put negative toe in BMW's because setting the toe at factory spec - which is zero toe - makes the car a little twitchy, meaning the steernig is very sensitive to input and on cupped road roads you have to constantly correct. We put negative toe in as well, but only 0.2 degrees which takes time to get right and costs more than $49.95 which is what most alignment shops charge for an alignment. I think some of the shops put in so much toe because they know they will sell twice as many tires on that car and then to cover it up blame the car, suspension, bushings, road condition and outer stellar planetary alignment as the cause for the cupping. Find a very good alignment shop and pay them to do it right.
