Old 6th May 2007, 03:22   #1
SoCaLE39
SoCaLE39's Avatar
Garage: Avus M5
Sales Feedback: (5)
2000 M5 - Oil residue in plenum
Lately I have been burning oil more than usual, so I decided to take off the plenum top today to take a look. I found that there is some oil by the crankcase vent valve and a slight residue on the velocity stacks. I'll post a picture later. So do you guys think the main cause is that theventilation valves are bad? I went ahead and ordered them just wanted to see what you guys thought....
I also forgot to mention that I was running 5w-30 and I just did an oil change with 10w-60 TWS oil.
2000 Avus Blue M5 - SOLD
The Mod List:
Dinan Exhaust - Dinan Rear Sway - Eibach Coilovers - 19" Vs-XX Work Wheels - AE Headlight Upgrade - Predator Angel Eyes - E60 Short Shifter - DICE Ipod System - Sink Drain Mod - Custom Rear Diffuser
SoCaLE39 is offline
Old 6th May 2007, 03:30   #2
rdm190
rdm190's Avatar
Garage: 2001 Carbon Black
The amount of oil you are describing is perfectly normal. I asked the M tech at my dealer this exact question when I had me plenum apart to replace the evap valve.
You should be running 10w-60 on a 2000, or are you after the ring change?
2001 M5 Carbon Black/Black Extended
Hella Euro Headlamps/Umnitza LED Angel Eyes/UF IATS/MVIV NAV Computer/20% Tint all around
2008 Ford Explorer Eddie Bauer 4x4. Takes the bad weather beating for the beast.
1995 Ford Mustang Cobra
2006 SeaDoo RXP
rdm190 is offline
Old 6th May 2007, 03:53   #3
Habu
Garage: E39 M5 TiAg
Sales Feedback: (3)
SoCaLE39,
I agree with rdm190 slight traces of oil is ok. When was your motor built? If it was before 03/00 then I think you need to put 10w60.
Bob
Habu is offline
Old 6th May 2007, 05:07   #4
SoCaLE39
SoCaLE39's Avatar
Garage: Avus M5
Sales Feedback: (5)
I also noticed oil in the breather tube coming out of the valve covers when I replaced my vent hoses. Is this ok?
Here are some photos:
Size:  434.1 KBName:  IMG_8359.jpg
The Mod List:
SoCaLE39 is offline
Old 6th May 2007, 05:32   #5
derck_mullin
derck_mullin's Avatar
Garage: 2000 Anthracite
Dude, looks really good. I'm constantly amazed at how well the motors of these cars look. Oil consumption in these cars can be normal, even if they have the newer rings. Just keep an eye on the oil level and fill as needed. As far as the oil, I've seen coated intakes on other cars...yours is obviously no where close. You could replace the oil control valves if you're in the mood, they only run about $55 ea and are really easy to get to.
Derck
Mine 2000 Anthracite, 70K, 13.17@106.7...looking for 12s...SOLD!
Hers 1998 Trans Am Convertible, 40K miles, auto, stock for now, 13.8@102
MINE...2002 Sand Beige Metallic F-250 Crew cab Powerstroke Turbo. Mods to start!!!
derck_mullin is offline
Old 6th May 2007, 07:40   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i posted pics of mine at some point in the past, i think if you search 'oil in plenum' you'll find them for comparison. Not much different than yours really, which is normal.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 7th May 2007, 01:24   #7
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
+1.. Quite normal, nothing to worry about..
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Old 7th May 2007, 06:15   #8
rdm190
rdm190's Avatar
Again, looking at your pics, normal.
2006 SeaDoo RXP
rdm190 is offline
BMWNA pressrelease on 6-speed manual M5 kees E60 M5 and E61 M5 Touring Discussion 10 9th February 2008 07:50
BMW M5 vs. E63 AMG - in depth review - w/ pictures now kwaobus E60 M5 and E61 M5 Touring Discussion 19 5th April 2007 04:04
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
All BMW M5 E60 Press Releases + Official Pictures Gustav E60 M5 and E61 M5 Touring Discussion 73 20th July 2004 02:04
Page generated in 0.14429 seconds with 12 queries
