Old 5th May 2007, 06:06   #1
m5ed
Garage: m5 black
just got a v1 but have a problem
hi all
i just bought a valentine one detector but when i put the cig lighter power adaptor in it appears that the plug is too long to get power from the socket...i dont want to hardwire the unit into the car...does anyone have a solution like a shorter adaptor i can get from radioshack? any help would be appreciated thanks
m5ed is offline
Old 5th May 2007, 07:14   #2
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
Telephone wire with standard RJ11 ends should work.
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Old 5th May 2007, 07:27   #3
Amir M5
Amir M5's Avatar
Garage: 2000 Metallic Anthracite M5
Originally Posted by m5ed View Post
hi all
Perhaps one of these might work
00 Anthracite Metallic
Dinan Exhaust | AA CAI | UUC Clutch (Stage 2) | Rogue Octane SSK + WSR | TC Design Rear Sway Bar Brackets | Dinan Rear Sway Bar | StopTech 4 Wheel BBK | Matte Black VMR CSL Wheels | ümnitza 6000K HID Foglight Upgrade | ümnitza 6000K Lowbeam Upgrade | ümnitza Predator ICE AE Upgrade | ümnitza Reverse HID | Hella Euro Angel Eyes | Hella Euro Celis Smoked Tails | Smoked Side Markers w/PIAA White LED | CA Automotive Black Carbon Fiber Grill | LED Interior Light Upgrade | Hardwired V1 Radar Detector | Ai Design Rear-View Mirror | V1 Control Panel | ACS Black Carbon Fiber Dash Trim | ACS Black Carbon Fiber Steering Wheel Trim | Full Leather Euro Dash Retrofit w/Euro Armrest | 01+ M Steering Wheel Retrofit | 01+ 16:9 Widescreen Retrofit | MKIV DVD Nav Retrofit
Amir M5 is offline
Old 5th May 2007, 07:29   #4
m5ed
Garage: m5 black
sorry if i wasnt clear with my question but it is the receptacle in the car (where the cig lighter plugs in) that appears to be too shallow for the cig lighter power adaptor of the v1 so i dont know if anyone thats using a v1 in their e39 but not hardwired into the car experienced the same problem and found a solution? thanks
m5ed is offline
Old 5th May 2007, 09:03   #5
Amir M5
Amir M5's Avatar
It was clear for me, the picture I posted is an auxiliary power adapter, it plugs into the flashlight socket in your glovebox, and then you can plug the v1 lighter adapter into that. BavAuto.com has them for 8.95.
If you don't want to do that, you can purchase a multi port adapter, which plugs into the cig lighter port and then gives you two ports, these usually have enough depth in them.
As far as getting a different adapter that would work with the v1, I don't think there is anything out there.
Is there a reason you don't want it hardwired? Once it's hardwired, the v1 can be removed in seconds and just as easily put back.
Amir M5 is offline
Old 5th May 2007, 11:48   #6
E55AMG2
E55AMG2's Avatar
V1's power adapter works perfectly with the M5, you might have to wiggle it into the power socket a bit, but I assure you it does fit. You might check that there is nothing in the socket blocking the adapter from going in.
Either way, your fear of (or reluctance to) hardwire is a bit unfounded. The kit can be installed in about 5 minutes, and removed in the same amt of time w/o damage to the vehicle. That way, you can have the V1 up and out of the way (and out of sight from cops/theives/radar detector leeches).
E55AMG2 is offline
Valentine V1 Install w Remote Audio Adapter and Concealed Display - With Pic's! rlpM5 E60 M5 and E61 M5 Touring Discussion 69 1st April 2009 01:06
Vanos problem ilundber E39 M5 and E52 Z8 Discussion 15 3rd November 2005 01:30
M6 gearbox problem after 2 months mat10874 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 11 25th September 2005 03:28
Engine hesitation problem ArrestMeRed E39 M5 and E52 Z8 Discussion 10 9th May 2005 22:45
Terminal problem with my B10? B10Ken ALPINABoard.com | BMW Alpina Discussion 16 15th August 2004 22:03
Page generated in 0.12333 seconds with 11 queries
