Can 265/35/18 & 285/30/18 be wrapped around OEM wheels
Hi all,
Someone locally is selling a half used set of Yokohama A048 semi slicks in the aforementioned sizes. Is there ANY chance that I could wrap these around the standard M5 wheels? I've got the PG2's for daily driving so I can just leave them mounted
Cheers,
Aaron
1999 Imola Red M5. Extended Caramel Interior Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
Cheers,
Aaron
Both should fit on the rears only. 265 too big for fronts. From memory, most spec that as a 9 inch wheel minimum for 265.
Cheers,
Aaron
-I ran 265s and 285s on the stock wheels. They fit, but the fronts are a little too big for the stock front wheels. The sidewalls will fold a little more than the rears (especially if you have no camber plates!) and you'll experience understeer. You can try running a little more psi in the front to compensate, and/or tuning you balance with an adjustable rear sway bar. You may need spacers (and then longer bolts or stud conversion) on the fronts. I ran 15mm, which was more than I needed and created a lot of bump-steer.
It's MUCH better to run 9.5" wheels in front with 275s, but I understand if you get a smoking deal on the others.
2007 Z4 M Coupe, Titanium Silver with Imola Red, black and silver interior -for details: www.mymcoupe.com
2003 M5, Imola Red with black and silver interior
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
2002 540iT, Sapphire Black with black and red interior
-Dinan stage 3 suspension with Koni shocks
-StopTech brakes
-255/40R18 PS2s f/r on 18x8.5 BBS RG-Rs
-Custom interior trim and seat massagers
-NavTv with DVD
yeah I should really get another 2 rears for the front... was just a thought.. they're only AUD$500 for the set of 4... and while I do have GC camber plates it does sound like im pushing the preverbial sh1t up hill.. never mind... 'twas just a thought .
Palantirion... your Z4m... VERY nice
-StopTech brakes
-Seat massagers
-StopTech brakes
-NavTv with DVD
