Old 27th April 2007, 01:11   #1
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
Interesting Dyno Factoids (Dyno Dynamics, Mustang, Dynojet)
I got these from the shop that is about to dyno my M Coupe. It is consistent with what I have been told elsewhere but certainly an interesting read:
20) My car makes 300 hp but your dyno says it makes 215. What is up? Our dyno is the most accurate measurement of torque at the wheels. More accurate than most. No "interpolation" or "estimation" or "inertia factors" are applied like they are on other competitors' lesser machines. What this means is that this is the actual torque being applied at the tire. Typically, a 300hp all wheel drive car will measure in around 210-215 on our dyno. This is normal.
21) I went to a Mustang dyno and they said theirs reads low, but you say yours reads low. Is this just some trick used by tuners? The Dyno Dynamics is known throughout the industry as being the "heartbreaker" dyno - because it breaks the heart of every man that thinks he has 500 hp when he really has 350. The Dyno Dynamics reads lower than the Mustang. It reads WAY lower than a Dynojet. It reads WAY lower than a Dynapack (which actually reads too high on tip-in). The closest in numbers (at low HP) is the mustang, but using the above example, the same 300hp car was dyno'd back to back on a Dyno Dynamics 450 LowBoy (what we have) and a Mustang AWD500E (what some other guys have), and that 300hp rated car consistently read 223 on the Dyno Dynam ics and 249 on the Mustang. One hour apart, exact same car, same town, same altitude, etc.
22) Why dont you just make your numbers look high to be the same as some others? Dyno correction is not a fixed amount. In other words, adding 30% at xx RPM and xx power does not translate. i.e. Using the above example, a car that makes 225 is about 1.3 to get 300. A 900hp car on this dyno is NOT making 1200hp ! Dyno numbers should be used for relative back to back comparison, and nothing else.
23) How do I compare my dyno results to others with similar setups? For Subaru owners, there are enough internet resources to compare, but essentially, Dyno Dynamics and Dynapack are the only 'consistent' numbers, and Dynapack reads very high, Dyno Dynamics very low. We can help you seek out other similar results. A great resource listing a slew of Dyno Dynamics HP baselines is available in the Gallery section at the KTR Performance Dyno Gallery Web Site. It should be noted that KTR uses atmospheric correction, which we do not use on our dyno plots.
24) How do I compare my pulls to Mustang Dyno, or a Dynojet, or a Dynapack? Every dyno is different. If you want dynojet or mustang-ish #s you have to multiply by 1.18 or so, 1.25+ for DynaPack. But remember, this is just ballpark, as it is not linear.
BKH is offline
M6 Kelleners / Schrick Cams, Active Autowerke CAM ECU, Supersprint X-Pipe & Mufflers KeithTa E60 M5 and E61 M5 Touring Discussion 73 19th January 2009 06:42
AEM Filter Dyno - Very interesting TQ2K E39 M5 and E52 Z8 Discussion 9 3rd March 2007 20:39
Superflow vs Dynojet Dyno? Atrain E39 M5 and E52 Z8 Discussion 2 24th September 2006 13:21
dyno graph for new '03 Mustang Cobra! AndyMenard Off Topic Forum 6 30th September 2002 15:03
'Mustang Dyno' Run on my M5 BM5VIUS E39 M5 and E52 Z8 Discussion 9 31st May 2002 16:07
Page generated in 0.08665 seconds with 11 queries
