Old 26th April 2007, 11:06   #1
Close Encounter
Close Encounter's Avatar
Garage: Jet Black 540i/6
Final suspension question, how many turns on rear koni yellows?
I'm installing the GC coilovers this weekend, 430fronts/380 rears. I'm going to set the rear dampers to 3/4 turn from full soft, and the fronts initially to 1 whole turn from full soft.
I do not want to have to mess with the rears again, so is 3/4 turn from full soft a good setup?
Thanks!
Close Encounter is offline
Old 26th April 2007, 15:39   #2
Lscman
Garage: E39
Thanks!
I would say definitely not! The 3/4T from full soft setting is for folks who are sensitive to ride quality & want to maintain stock ride comfort with stock BMW springs!! The 380 rears are much stiffer than Dinan springs and Dinan recommends 1-1/4T for their stockish rate setup.
You have not stated what you do with this car. Without knowing your duty & ride expectations, I'll make a "wag" and say something between 1-1/4T from full soft and 1-1/2T from full soft might work.
Resolve never, screw genuine.
Lscman is offline
Old 27th April 2007, 02:15   #3
Close Encounter
I'm not exactly sure what my expectations are, I don't want a brutally harsh ride but I don't require alot of comfort either. If I had to set it between the two it would definitely be more towards performance.
All I can really exploit up here are long, curvy highways and sweepers, no raceways or tracks, and the auto-x's are usually in school parking lots and not friendly towards long-legged cars. All I know for sure is that I don't want to bottom out, and I frequently carry rear passengers.
Thanks!
Old 27th April 2007, 02:52   #4
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
I would send an email to the guys at Discovery Automotive and ask them. They have set up countless M5's and I think they work closely with Ground Control. They should have some good ideas for you.
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
Old 27th April 2007, 04:45   #5
Lscman
Garage: E39
The correct way to set the Koni shocks is to count the turns from full soft to full firm and then calibrate them from the full firm setting. This method provides better calibration matching because the total number of turns varies from shock to shock. The max firm setting is always the same while the full soft setting might not be consistent. What you find is some dampers will allow an extra 1/4 turn or so in the soft direction.
I'd probably split the difference and go with 1-3/8 Turn from full soft.
If the total turn count from full soft to full firm turns out to be 2-3/4T, then you'd be close to a 50% setting. You can basically wind each shock to full firm and then back it down by 1-3/8 turns.
GC or Discovery may advise you on the optimal damper setting for the 380's. The guesstimate I offered should work good for performance street use, autox and typical non-competition weekend flogging with that spring.
Lscman is offline
Old 27th April 2007, 04:49   #6
drallen
drallen's Avatar
Garage: M5 Jet Black
I am with Rick on this one...
I have the "softer" rear springs (early adaptor #280, Dinan bar in the middle hole) and I am running mine with 1 full turn out from full soft...so 1.25 turns out from full soft should be just about "right" for you...
I believe that I am running 1.25 or 1.5 turns out from full soft on the fronts with #430 springs and 275s on the front (on stock rear rims)...
I hope this helps...
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Jet Black 2002 M5
drallen is offline
BMW M3 - english pressrelease (with lots of pictures) kees E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 43 18th May 2007 15:09
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Ride Height pics of H&R29441 and 'custom' rear springs OldRanger E39 M5 and E52 Z8 Discussion 9 24th June 2005 05:34
Suspension is tired: PSS9 vs. GC vs. Koni vs. ??? Challenge Motorsports E39 M5 and E52 Z8 Discussion 11 13th January 2005 14:26
Some question about self-levelling suspension Azmir E34 M5 Discussion 6 26th January 2003 12:26
Page generated in 0.17356 seconds with 11 queries
