Old 28th March 2007, 01:04   #1
tranck
tranck's Avatar
Garage: 2000 M5 - Silverstone Metallic
Creeking front end noise when hot FINALLY fixed!!
If you have been reading a thread on this persistent issue of mine, you know that I replaced the front sway bar bushings (actually, tefloned them 1st) THEN the front sway bar because my tech said that at my mileage (130,000) the paint had to be worn or burned off from excessive front end heat and replacing only the bushings would not do it.
$1100 later, still squeaked, creeked - nice.
Again, ONLY when the car was hot - bumber to bumber traffic etc. hit the brakes or small bump - there it was - aggravating as heck.
Wrote the dealer service manager lengthly e-mail about these fruitless efforts.
I had just replaced the control arm bushings because of steering wheel vibration when braking - this after replacing the rotors did not fix THAT problem.
Had the shocks replaced two weeks ago so I KNEW they did not cause the squeaking - what finally fixed this was replacing the control arms.
Done.
Dealer and I are sorting out what I owe them or vice-versa at this point but, if you DO eventually have this problem, it's the control arm replacement that finally fixed it and if you have steering wheel vibration when braking, replace the control arm bushings before any brake job.
Call me the gunea pig.
Oh yeah, and if you have a ticking in your engine - rod bearings, I know about THAT problem as well.
Btw, if your car starts to run like crapola and your friendly SES light indicates carbon buildup - it's the heads - I know about THAT problem too.
But you know what, my two beloved VANOS units are purring - scratch that DIESLING right along.
tranck is offline
Old 28th March 2007, 01:18   #2
Need4Spd
Need4Spd's Avatar
Was it the "control" arm or the "thrust" arm bushings? The control arm is forward of the thrust arm. There are two arms. Thanks!
Need4Spd
Need4Spd is offline
Old 28th March 2007, 01:24   #3
tranck
tranck's Avatar
I was told "control arms" plus the linkage.
tranck is offline
Old 28th March 2007, 03:02   #4
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Good to know, thx for posting!
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 28th March 2007, 03:25   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
See if you can get the part number so we are sure it is control arms and not the 'thrust arms".
gsfent is offline
Old 28th March 2007, 04:47   #6
StevenZ
Garage: BMW M5 Silver/Black
From other posts it appears that the thrust arm bushings need replacement before 130,000 miles. You are probably going to be on your third set soon unless you switched to a more durable bushing.
130,000 miles is about time for the control arms to need replacing. They are more durable than the thrust arms but they do give up eventually. Note that the recommended procedure is to replace the whole control arm because it includes a ball joint on one end and a bushing on the other. My information is that they should be replaced together, so replace the whole arm on both sides of the car. You should be good for at least another 100,000 miles on control arms!
2000 M5 Silver/Black 03/00 build
StevenZ is offline
Old 28th March 2007, 08:26   #7
gherardini
gherardini's Avatar
Garage: 2002 M5 Titanium Silver
Sales Feedback: (5)
Send a message via ICQ to gherardini Send a message via Yahoo to gherardini
way to take one for the team. thanks! i'm subbed on this one for future reference...
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Steath Auto Turn Signal Bulbs
- Predator ICE v2.1
- Xenon fog lights
- CNS Racing clutch
- TC Designs Sway Bar Brackets
'87 K75S - "Maybellene"
'00 R1100S - "Tresor!"
Sierra Vista, AZ
gherardini is offline
Old 28th March 2007, 11:21   #8
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Me 2...
Big thanks for posting, Tranck!
David
DavidS is offline
Old 28th March 2007, 22:13   #9
tranck
tranck's Avatar
gsfent and DavidS - here are the two relevant part numbers - I won't give you the nut and clamp etc #'s but here ya go:
31-12-1-141-961 and 962
Whether they are Thrust or Control arms - whatever they are, they fixed this persistent noise completely.
tranck is offline
Old 28th March 2007, 23:01   #10
gsfent
gsfent's Avatar
Thanks for posting the part numbers. I will leave it to the experts, but I think this is the lower control arm (BMW calls it wishbone, item #12). I believe the thrust arm is part #5.
Here is the realoem link:
http://www.realoem.com/bmw/showparts...31&fg=05&hl=21
The best news is the problem has been solved!!
gsfent is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Bra (Colgan front end mask)..used once jcdmoss1 For Sale or Wanted 0 2nd August 2002 20:51
Re-clear-coating front end HBRAMSTEDT E39 M5 and E52 Z8 Discussion 5 3rd July 2002 22:08
The ultimate front end alignment. Jim Dolan E39 M5 and E52 Z8 Discussion 7 21st September 2001 13:38
Page generated in 0.15532 seconds with 11 queries
