Old 27th March 2007, 23:22   #1
El_Mono
El_Mono's Avatar
Garage: M5 - Carbon Black
Extended Maintenance - Still Available ?
So I called my local stealer, and the guy says "not available, maybe April 1st with new pricing". So I call another dealer that is a little farther away from me, and they quote me 1195.
What gives ? Who is giving me bum dope?
2003 Carbon Black / Silverstone - M5 (duh)
All the fixin's
Bluetooth - SE w810
Miltek Exhaust
Aux Input - Not sure why I installed this, Sirius RULES.
Sirius - The only way to go ...
El_Mono is offline
Old 27th March 2007, 23:32   #2
BMWMPWR
BMWMPWR's Avatar
Garage: Joji Nagashima designed BMW - I hope you know who this guy is!
Sales Feedback: (6)
$1195 is pretty much the standard for the last several years. Most mark up to take home the difference.
And remember, this is maintenance, not warranty- = 1 oil change every 15k miles, and 30k, 60k, 90k service inspections which = 1 inspection every 2 or more years. Not so sure it's worth it- maybe I should edit out this latter opinion.
Hope that helps tho.
Neil
BMWMPWR is offline
Old 27th March 2007, 23:34   #3
El_Mono
El_Mono's Avatar
Apparently the selling point is the brake job. I have 29k miles on my car, and the maintenance plan is set to expire in the beggining of April. I don't drive my car enough to actually get the green bar oil change, but instead get the low mileage annual oil change. I don't want to waste my money, but I'd love the peace of mind that whatever happens to the car int he next 2 years (already am CPO'd) would be taken care of.
All the fixin's
Bluetooth - SE w810
Miltek Exhaust
El_Mono is offline
Old 27th March 2007, 23:38   #4
BMWMPWR
BMWMPWR's Avatar
Sales Feedback: (6)
oh yea brakes.... this is true... I've heard tho that some dealers say "its not covered." So perhaps check with your local dealer if it would be covered under the maint plan and get that in writing. Then buy the plan from the dealer with the lowest price on the maint plan, since it will follow the VIN, not keep you at that or any specific dealer.
BMWMPWR is offline
Old 27th March 2007, 23:48   #5
jclyman
jclyman's Avatar
The first dealer was lying to you ... except the maybe new prices on April 1. $ 1,195 is about a cheap as it gets and it is a BMW NA program.
I believe brakes are covered, and it is in the plan description.
- Daniel Boorstin
jclyman is offline
Old 28th March 2007, 18:37   #6
sshu930
sshu930's Avatar
Garage: M5 Sterling Grey
I just got the maintenance agreement done a few days ago for $1195, worth it IMO.
Scott
03 M5 Sterling Grey
05 X5 4.4i Black
sshu930 is offline
Old 29th March 2007, 04:22   #7
YAD
YAD's Avatar
Garage: 2003 M5 Dinan S-2
what are the major exclusions with extended warranty
I have never purchased an extended warranty. What are the major items that are excluded?
YAD is offline
Old 29th March 2007, 05:02   #8
ard
ard's Avatar
So, this is easy. 29k and you brakes are __X__ mm thick.
In 2 years, at __Y__ miles per year your pads will be:
X- ((10-x)/29000 * 2Y)
If this number is less than 2mm, or if the rotors will be under 30.4mm, then you will need brakes and this is a deal.
If you will not wear out the brakes, why deal with the irritation of seeing the dealer for service...
A
ard is offline
Old 30th March 2007, 00:30   #9
El_Mono
El_Mono's Avatar
Well I did it. Took less than 10 minutes. I'm treating this like insurance, not something you want to have to pay for, but just in case, you'd be glad you had it. My car already had the CPO, so for the most part I feel comfortable for the next 2 years.
I guess the part that worries me the most is that after speaking to dealer #1, twice in 6 months and the sales manager not knowing if it was still available, I was able to complete the transaction in 10 minutes from another dealer
All the fixin's
Bluetooth - SE w810
Miltek Exhaust
El_Mono is offline
Old 30th March 2007, 04:49   #10
ard
ard's Avatar
Tell you what- get the M mobility kit replaced, and the brakes and coolant flushed and you will only be loosing $2-400 on the deal. 29k miles you haven't even done inspection 1 yet, right?
(They tend to forget the coolant needs flushing every 3 years and the brakes every two)
Your CPO is a whole 'nother story... worth having.
Good luck
A
PS Have you changed your diff and tranny fluids? You might consider this.
ard is offline
USA extended warranty and/or maintenance idivethesea E60 M5 and E61 M5 Touring Discussion 4 30th September 2005 00:26
Extended Maintenance and Warranty hal2000 E39 M5 and E52 Z8 Discussion 6 24th August 2005 11:41
New BMW Extended Maintenance Program? bbfl E39 M5 and E52 Z8 Discussion 10 15th March 2005 20:49
Who has purchased the extended maintenance agreement? sjfamily E39 M5 and E52 Z8 Discussion 11 17th February 2005 23:34
Extended Scheduled Maintenance Program HireM5 E39 M5 and E52 Z8 Discussion 3 29th June 2004 19:23
Page generated in 0.14279 seconds with 11 queries
