Old 27th March 2007, 22:04   #1
TurboCarrera
Garage: 00 M5 Silver
Axxis Pads/Brake Lining Warning/Noncompatible?
So my brake lining warning lights came on last week - not bad for 77,500 miles on the original factory brakes - and in anticipation, I already had a set of Euro floating rotors and Axxis pads sitting in the garage.
This morning I changed the pads and rotors, and replaced the lining sensors with new ones. The brakes now work fine, but the "Check Brake Lining" warning light and message are still on.
Is this something that I have to reset with Peake, or do the sensors not work correctly with aftermarket pads? The correct cutouts were in the pads and the OEM sensors fit fine. I took care with the plugs at the other end.
Thanks,
Steve
00 M5
02 G500
TurboCarrera is offline
Old 27th March 2007, 22:06   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
iirc, there is a procedure to reset the 'check brake linings' light. Something like leaving the key in the run position before starting for 10-15sec? Can't remember the specifics, but if someone else doesn't reply, it's worth a search.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 27th March 2007, 22:09   #3
sjdennis
sjdennis's Avatar
Garage: 2000 M5 Avus Blue
Probably a re-set issue for the light. I did the same change as you with the euro rotors and axxis d+ pads without issue, however I changed them before the light came up on the original pads.
Peake tool should be able to correct or you can take it to the dealer and ask them for a re-set.
Dennis
sjdennis is offline
Old 27th March 2007, 23:53   #4
TurboCarrera
I Peaked it away.
Hope I get 77k miles out of my new brakes!
BTW, the floaters are pretty interesting temperature-wise. When the rotor section is too hot too touch, the hub section is cool, which is nice for the bearings. One of these days I'll laser the difference.
Steve
An alternative low-dust brake pad to the Axxis Deluxe Plus DZeckhausen E39 M5 and E52 Z8 Discussion 54 11th February 2008 17:38
Interior hood lining SteveT E34 M5 Discussion 15 18th September 2006 17:47
The Quest for the Perfect Street Pad: Mintex Red Box Pads vs. Axxis Deluxe Plus Pads Need4Spd E39 M5 and E52 Z8 Discussion 37 3rd April 2006 06:54
group buy anyone in uk- axxis pads mohan E39 M5 and E52 Z8 Discussion 3 31st May 2005 00:17
POLL: Axxis Delux Plus brake pads DavidS E39 M5 and E52 Z8 Discussion 12 27th May 2005 00:12
Page generated in 0.10131 seconds with 11 queries
