Old 27th March 2007, 07:09   #1
SoCaLE39
SoCaLE39's Avatar
Garage: Avus M5
Sales Feedback: (5)
BMW Recall = New DME
Well after having to take my beast in for the recall it turns out the update fried my dme so bmw is replacing it. Good thing is that with the new recall my service rep (friend) told me I will have a new warranty with the recall and troubles I have had. Although bmw gave me a mazda 3 rental, the weekend is when the beast comes out and i'm already missing it .
For those that need to get the recall done, try to avoid it at all costs or have your dealer "say" it was done if you know them well enough.
2000 Avus Blue M5 - SOLD
The Mod List:
Dinan Exhaust - Dinan Rear Sway - Eibach Coilovers - 19" Vs-XX Work Wheels - AE Headlight Upgrade - Predator Angel Eyes - E60 Short Shifter - DICE Ipod System - Sink Drain Mod - Custom Rear Diffuser
SoCaLE39 is offline
Old 27th March 2007, 07:20   #2
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Had mine done a few months back with no issues.
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 27th March 2007, 07:44   #3
Need4Spd
Need4Spd's Avatar
The problem with that is that it won't communicate with certain smog check equipment and then fail. Depending on when that happens, the records will show that the recall has been done so fixing it to pass will be on your own nickel.
Need4Spd
Need4Spd is offline
Old 27th March 2007, 07:45   #4
Jon@TheMShop
Representative for themshop.com, m5board.com Sponsor
Garage: '98 M3 and '07 335i sedan
Send a message via AIM to Jon@TheMShop
There have been known issues that during programming either the GT1 or Progman computer will lock up thus "frying" or losing all info. for the M5 DME. In which case a new one will be installed.
Jon C.
Jon@TheMShop is offline
Old 27th March 2007, 18:59   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i've heard the stock dme will only take so many 'reflashes', anyone know if this is true?
I still need to get this done, first attempt at asking the dealer to 'do it but not do it' was declined (though i didn't ask the right person). I have a feeling my lastest dinan software already incorporated the fix, as my car passed smog at the corner smog station.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 27th March 2007, 19:38   #6
Jon@TheMShop
Yes it's true. On the GT1 for example it will tell you that the control unit has X amount of times to be reflashed. I think the limit is 13 times.
Jon C.
Old 27th March 2007, 20:26   #7
mottati
mottati's Avatar
so i wonder what happens if i go in and i'm at the limit? bmw has to give me a new dme because of the recall? (really don't know how many times my car has been flashed, but it's been several).
mike
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 27th March 2007, 20:49   #8
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #23 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (3)
I had the emission recall on my S2 done by BMW of Greenwich. They're also a Dinan dealer & reinstalled the S2 software after doing the warranty work. It was itemized on the bill. No charge for any of this.
2003 Jet Black ///M5 Dinan S3 #23
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger
, S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils, OKD Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Stage 3 Dinan/JRZ Suspension, Dinan/Brembo Brakes, Rennline Pedal Set w/ throttle heel/toe ext,, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Subframe Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Winter: 275/35ZR-18 Michelin Pilot Sport PS2; Drags: 2 Nitto NT-555R Drag Radials 285/35R-18; Blinder-M45-X-treme, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder
1/4 mile: 11.795 @122.20 mph, 60' - 1.819
Kelster is offline
Old 27th March 2007, 20:56   #9
Habu
Garage: E39 M5 TiAg
Sales Feedback: (3)
Jon@TheMShop,
That's good information. If you do get a replacement, I wonder if you have to have the dealer install it for you. I noticed that on mine, it had sticker with the VIN on it. The thought occured to me that when you unlock your computer for the MAFS test you need your VIN.
Bob
Habu is offline
Old 27th March 2007, 21:12   #10
mottati
mottati's Avatar
Originally Posted by Habu View Post
Jon@TheMShop,
Bob
i'd imagine this is a dealer only (or a shop with gt1 or similar) issue to code/program the dme.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav GTBoard.com: General Sportscars 74 16th April 2008 00:04
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav GTBoard.com: General Sportscars 12 20th September 2007 20:14
Complete BMW M6 Convertible Press Release in English and German (Short Version) Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 23rd June 2006 05:27
From Formula1 to the street... now with additional SwissPower!!! 2004M5 E60 M5 and E61 M5 Touring Discussion 0 22nd June 2005 18:44
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E60 M5 and E61 M5 Touring Discussion 53 12th May 2005 02:51
Page generated in 0.22561 seconds with 11 queries
