Old 26th March 2007, 03:19   #1
Theodosia
Theodosia's Avatar
Garage: 2001 M5 Carbon Black
Resetting Key Fob
Just took the beast out of hibernation this past week but now the remote functions on both key fobs don't work. At first thought it was because they hadn't been used and the batteries had died (probably true) but figured that a bit of driving would charge them up and they would work again, but that hasn't happened.
Last fall when I bought the car it only came with one key so I bought a new key from the dealer and the tech there programmed the new key. A week later I discovered the first key didn't work so he went through a little procedure and then they both worked, but I can't remember exactly what that procedure was. Something like turning the ignition to the second position with one key and pointing the other key (need two keys?) at the back of the car and holding the center button. I've searched all through this forum and the rest of the internet, but have not been able to find instructions on programming a key fob to lock/unlock the car. I will need some other work done soon at the dealer so I'll have them reprogram the keys then, but I still wouldn't mind knowing how to do this myself if it ever happens again.
John
01 M5 Carbon Black/ Black/Red
98 528 Jet Black/Black
Theodosia is offline
Old 26th March 2007, 04:42   #2
robluvs2xlr8
robluvs2xlr8's Avatar
Garage: 2001 BMW M5 Royal Red
Send a message via AIM to robluvs2xlr8
Instructions are on this link:
Remote Key Programming
-2007 BMW Z4 M Roadster
(Interlagos Blue / Black)
stock
-1992 Honda Civic LX
(White / Tan)
30mpg
-2001 BMW M5
(Royal Red / Caramel)
-Sold-
robluvs2xlr8 is offline
Water Damage to Key Fob EM_5 E60 M5 and E61 M5 Touring Discussion 15 11th February 2007 13:10
Disable trunk unlock on key fob? gsfent E39 M5 and E52 Z8 Discussion 10 10th January 2006 23:00
Key Fob Issue - you too? MAH E39 M5 and E52 Z8 Discussion 15 11th February 2005 21:35
Inoperable Key Fob (Long) x703jko E39 M5 and E52 Z8 Discussion 20 12th November 2004 09:58
Strange problem with key button to unlock doors... fumaras E39 M5 and E52 Z8 Discussion 2 11th February 2004 04:43
Page generated in 0.10479 seconds with 11 queries
