Old 25th March 2007, 22:52   #1
kneedeep
Garage: BMW 2002 M5
Feedback on driving with broken sway bar link?
ok so I was replacing my brake pads and noticed a slight problem with my sway bar! Guess it's time to order new sway bar links and stabilizer.
Can I drive like this for a few days without causing more damage? Might take a day or 2 to get the parts.
kneedeep is offline
Old 25th March 2007, 23:34   #2
m5admirer
m5admirer's Avatar
Garage: '01 M5 - carbon black
Broken rear brackets are a common thing on our cars. The front links are less common but I think I remember having mine replaced (warranty is great).
Take the turns easy and you will have no problem driving the car until you get it fixed.
Rob.
m5admirer is offline
Old 25th March 2007, 23:43   #3
T-TRIM 540i
Garage: SC'd titanium Silver 2003 540i sport
Think about using the TC Design Brackets instead of OEM... Much better , last for ever , most likely....
T-TRIM 540i is offline
Old 26th March 2007, 00:56   #4
ard
ard's Avatar
I'd say it is more shocking to find a car that DIDN'T have broken brackets, at least once.
+1 on the TC Designs. If you buy stock, get 2 or 3... you'll need them.
A
ard is offline
Old 26th March 2007, 02:36   #5
Need4Spd
Need4Spd's Avatar
Note that he broke both the brackets AND the links. I agree about the aftermarket brackets. Don't have any suggestions about the links other than OEM. Possibly the links broke because of the broken brackets?
Need4Spd
Need4Spd is offline
Old 26th March 2007, 02:58   #6
1bad540
1bad540's Avatar
Garage: 2002 M5 Titanium Silver
I wouldn't run it too long as the bar can rub your brake line on that side.
1bad540 is offline
Old 27th March 2007, 16:01   #7
kneedeep
Garage: BMW 2002 M5
Decided to just zip tie the swaybar up and park it till the parts get here. Not worth risking cutting a line or braking something else.
kneedeep is offline
Old 28th March 2007, 06:25   #8
TurboCarrera
Garage: 00 M5 Silver
I pulled a rear wheel today and noticed that the inside two inches of tread were worn way down and chunked a little. Then I noticed the sway bar bracket on that side was broken. I corner hard and i guess with the lack of sway bar the suspension compressed enough to force the wheel on the inside edge when it was the outside wheel in a turn.
This was my third broken bracket; ordered the aftermarket ones today.
Steve
00 M5
02 G500
TurboCarrera is offline
Old 28th March 2007, 07:25   #9
CDW63
CDW63's Avatar
Garage: 2002 Carbon Black M5
My brackets are fine, but the support on the frame is broken off on one side. I have yet to find a shop with a TIG welder and a lift. I am going to call some muffler shops tomorrow to see if any have the equipment to weld the piece back on.
CDW63 is offline
Old 28th March 2007, 20:01   #10
sfm5
Garage: Jet Black M5
Just a side note, if you plan on replacing these brackets yourself, it can be a little involved. Beastpower describes this as a 30 minute job, but it turned into 3 hours for me, as it requires removing the links from the bar, which is facilitated by removing the wheels on both sides, which requires that the car is on jacks, etc.
If you have access to a lift, or can put the back end of the car easily on jacks, then it should be easier for you. But I'm still not sure how people can replace these brackets in 30 minutes!
sfm5 is offline
Redesigned BMW Sway Bar Brackets? ksmith80209 E39 M5 and E52 Z8 Discussion 9 13th August 2006 04:27
Dinan Sway Bar Question Richard in NC E39 M5 and E52 Z8 Discussion 1 8th April 2004 06:44
Rear Sway Bar Brackets canysmc E39 M5 and E52 Z8 Discussion 4 30th March 2004 07:11
Installed Dinan rear sway bar on stock suspension BostonRocket E39 M5 and E52 Z8 Discussion 6 9th January 2002 18:28
Page generated in 0.15042 seconds with 12 queries
