Old 25th March 2007, 08:55   #1
civic eater
civic eater's Avatar
Garage: M5 carbon black meallic
Using Denzo Iradiam spark plugs?
i was planing a trip to florda and my spark plugs were due to be changed so i went to buy the plugs and nobody cold get them in time ngk or bosh. the guy at the parts store sold me some denzo iradam spark plugs and assured me that these were comparible to the ngk. when i finialy replaced the plugs (took me 3 hrs.) i noticed that the factory ngk plugs had 2 tips and the new denzo ones only had 1 tip. have i down graded my using these $106 spark plugs? when i replaced the plugs i noticed a differance in power but my mafs were dirty at the time, and i have a feeling that the mafs messed up the air fuel mixture and has fouled the new plugs cause it acts like its a little donw on power again . should i remove these plugs and clean them or should i go drop another 100 somethig dollars and get the ngk plugs?
thanks for your help
civic eater is offline
Old 25th March 2007, 09:10   #2
robluvs2xlr8
robluvs2xlr8's Avatar
Garage: 2001 BMW M5 Royal Red
Send a message via AIM to robluvs2xlr8
Hmm...
When I got mine from the BMW parts dealer mine came with 4 tips
-2007 BMW Z4 M Roadster
(Interlagos Blue / Black)
stock
-1992 Honda Civic LX
(White / Tan)
30mpg
-2001 BMW M5
(Royal Red / Caramel)
-Sold-
robluvs2xlr8 is offline
Old 25th March 2007, 13:22   #3
gherardini
gherardini's Avatar
Garage: 2002 M5 Titanium Silver
Sales Feedback: (5)
Send a message via ICQ to gherardini Send a message via Yahoo to gherardini
i'd take 'em back where you got them and tell them they they are definately *not* doing their job in a comparable manner despite the sales geek's assurances and to either give you the plugs you wanted in the first place or refund your money.
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Steath Auto Turn Signal Bulbs
- Predator ICE v2.1
- Xenon fog lights
- CNS Racing clutch
- TC Designs Sway Bar Brackets
'87 K75S - "Maybellene"
'00 R1100S - "Tresor!"
Sierra Vista, AZ
gherardini is offline
Old 25th March 2007, 17:44   #4
Need4Spd
Need4Spd's Avatar
+1 if you're unhappy and think it's the plugs. I seem to recall reading a thread here that concluded that our engines are sensitive to spark plug type and that to stay away from platinum plugs (the kind with 4 prongs), but that's just my faulty memory. Use the search feature and see what you come up with. IIRC, some have used iridium plugs with success.
Need4Spd
Need4Spd is offline
Old 25th March 2007, 17:48   #5
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
If you do a search for "Denso Iridium"(spelling) you can find the correct part number.
But if you installed new plugs and the car still ran bad, you have other issuses. Even a standard copper single ground electrode plug should run with no problems for 5000 miles in these engines.
$106.00 for plugs!
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline
Old 25th March 2007, 21:10   #6
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
As I recall it, anyone who's tried anything other than stock has eventually switched back. The stock plugs work best - if your local parts store doesn't have them then order them online or from a dealer. Four electrodes and made by NGK - BKR6EQUP.
Cheers
JJ
jaj is offline
Old 26th March 2007, 02:39   #7
THRILOS5
THRILOS5's Avatar
Garage: 2001 m5 black
Sales Feedback: (3)
Im using Denso iridiums for almost 2 years now and the beast is running better than ever
e39 M5
Audi S4
300ZX tt 580hp@20psi
Mustang GT 5.0L
Suzuki GSXR750
THRILOS5 is offline
Old 26th March 2007, 02:58   #8
T-TRIM 540i
Garage: SC'd titanium Silver 2003 540i sport
I have been running them in My SC'd 540i since the begining and no problem producing a steady 440 WHP and 391 WTQ . AND I will be running them after the total rebuild and refit that will be more demanding on the plugs and I will let you know what the results are in about a month.... They are really well designed as far as I can read anywhere.....
T-TRIM 540i is offline
Old 26th March 2007, 08:04   #9
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i ran denso irridiums for a year or two as well, no issues. Not any better, not any worse. As long as you have the correct part, i wouldn't worry about the plugs, but try to figure out your other issues. I think the 4 electrode thing is much to help extend the life of the plugs.
fwiw, i replaced my plugs today, got them from the dealer yesterday (bmw/ngk) for $8 and change per plug. I also replaced the little boots that connect from the coil to the plug, figure couldn't hurt after nearly 90k, for a couple bucks per cylinder extra.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 26th March 2007, 17:31   #10
Osodog
Osodog's Avatar
Garage: M5
Mike, do you get your supplies at Concord BMW? I need to pick up some oil for an oil change as I am about to head out on a drive to San Diego later this week.
Visit my web site to help raise funds for LLS:
http://pages.teamintraining.org/sf/Yosemit109/jmilne
Osodog is offline
DIY Spark Plugs, as requested. (Pics inside) rdm190 E39 M5 and E52 Z8 Discussion 61 Yesterday 20:28
Tips for changing spark plugs on E39 M5 jaj M5 E39 and E60 tips & tricks 22 11th August 2009 08:51
What Spark Plugs and Wires for my M5? EvilM5 E39 M5 and E52 Z8 Discussion 14 19th February 2007 06:38
Changed Spark plugs, old ones were so foul cali6869 E39 M5 and E52 Z8 Discussion 17 16th January 2005 20:18
Page generated in 0.14235 seconds with 11 queries
