Figured this may be of use to several of us and I'm not sure if a thread was already created under the tips section of this board.
If you have been stuck getting your HomeLink system to work with your garage door opener after following the instructions in the M5 user manual on pages 91 - 93, this thread is for you......
Amazing. Here I have lived for over a year without the convenience of the HomeLink feature which I currently have in two cars now. After gathering the information supplied on this forum, things worked out like a charm and I've got both my garage door openers programmed using positions 1 and 2 on the HomeLink. Since there is some concern about older garage door systems, let me just say that I have a Liftermaster+ series that was installed in 1998.
I went to the HomeLink web site and had to watch the video 8 or so times to get the instructions since you cannot pause it and you have to watch the dreaded introduction over and over where the girl comes home all happy to her automated house and PC, then read the instructions in the M5 manual under "BMW Universal Transmitter" on page 92 and put the two together.
Let's just make this easier shall we? Here are seven steps you can follow to the T......
1. Put your car key in the ignition and turn the ignition to position 2.
2. Press and hold the two outer keys on the HomeLink receiver until the indicator lamp flashes rapidly, then release the keys. The three channel keys are now cleared.
3. Hold the hand-held garage door transmitter toward the HomeLink receiver (no more than 2 inches away), and at the same time press the garage door transmitter key and HomeLink receiver key you wish to program....any one of the three will work. Your garage door will open since you pressed the garage door remote key, but don't worry about it.
4. Release both keys as soon as the indicator lamp on the HomeLink receiver flashes rapidly.
5. Press the programmed key you selected on the HomeLink receiver and the indicator lamp should illuminate solid (if it does you are done), if it blinks rapidly for 2 seconds then goes solid, continue to the next step.
6. This step is for garage door openers with a rolling code feature. Get a step ladder and press the learn or smart button on the garage door opener in your garage.
7. Within 30 seconds, press the programmed key you selected on the HomeLink receiver for 2 seconds and the training is complete. You should now be able to use your HomeLink receiver to open the garage door.
Repeat steps 3 - 7 if you have more than one garage door opener.
