Old 24th March 2007, 18:04   #1
stilov
stilov's Avatar
Garage: AW 2000 M5
Just bought my beast and SES light came on
Well I have the dreaded AA and an E8.
Luckily at the first of the year they discontinued emissions period in my county.
How about that E8 though...will it cause the car to go into limp mode? I imagine AA will only trigger the SES light in cooler weather...today it's about 20 degrees cooler than it has been this week.
I just HATE that light looking at me all the time!!!
stilov is offline
Old 24th March 2007, 18:15   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
sounds kind of fishy, just bought the car, and now carbon blockage code? can you bring it back!? If all else is good with the car, get the powerchip patch. Off the top of my head, i don't know what e8 is, what does that code translate to?
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 24th March 2007, 19:35   #3
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
If your AA code is triggered by carbon blockage of the passages into the head, the weather won't have any effect on it. If it stays on all of the time, it will mask other codes that you might care about. That alone might justify the cost of the PowerChip patch even though your county doesn't require inspections.
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
Royal Purple Synchromax
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
Mike Krieger is offline
Old 24th March 2007, 20:10   #4
Fuddy
Fuddy's Avatar
Garage: Silver E39 M5
E8 is the evaporative emissions purge valve... I have the same code on my car
check out this thread:
Replacing Vapor Ventilation Valve...?
Fuddy is offline
Old 24th March 2007, 21:04   #5
stilov
stilov's Avatar
Garage: AW 2000 M5
I bought it from a private owner...other than that...the car is just about perfect. I cleared it and it hasn't come back and I test drove on long trips.
Never had a code while test driving.
stilov is offline
Old 24th March 2007, 21:06   #6
mottati
mottati's Avatar
the main thing will be the next few cold starts, that is the only time this is monitored. At any rate, if the car is otherwise good, i'd just do the powerchip fix, and never worry about AA again.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 24th March 2007, 21:10   #7
stilov
stilov's Avatar
Garage: AW 2000 M5
I probably will...I have the E8 code as well which is the valve behind and underneath the intake, so I may replace that at least.
stilov is offline
Old 24th March 2007, 21:16   #8
ard
ard's Avatar
E8 seems to be a popular code these days,
A
PS Bring it in for a diagnostic work up... (Inside joke.. just buy the valve and have it replaced- 3 hours, $75 for the part)
ard is offline
Old 24th March 2007, 21:17   #9
mottati
mottati's Avatar
A
i was going to recommend a good shop in the bay area!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 24th March 2007, 22:27   #10
Fuddy
Fuddy's Avatar
A
Fuddy is offline
SES Light came on but now it's off.... kirbanana E39 M5 and E52 Z8 Discussion 3 1st March 2007 16:21
SES Light - Engine Misfire! x703jko E39 M5 and E52 Z8 Discussion 24 8th March 2005 20:49
Help ! - SES Light - Dealer Help Needed London UK SSD E39 M5 and E52 Z8 Discussion 5 2nd November 2004 10:01
Post-headers & cats SES light question XrayMD E39 M5 and E52 Z8 Discussion 25 16th June 2004 18:12
My SES light saga continues... BostonRocket E39 M5 and E52 Z8 Discussion 16 18th May 2002 18:05
Page generated in 0.15839 seconds with 11 queries
