Throttle-Steer - BMW M5 Forum and M6 Forums
Old 22nd September 2001, 13:01   #1
jamesnj
Garage: 2000 Land Rover Disco
Throttle-Steer
What percentage of your steering is a result of conscious throttle steer when you're on track? I realize it'll be different for everyone, so it's more of a survey. On a windy road say going up to Tahoe do you ever use throttle steer? If so, to what degree?
Do any of you feel the pedal placement in the M5 is too far to the left?
Is WOT a European term or is it used in the USA too?
jamesnj is offline   Reply With Quote
Old 22nd September 2001, 13:10   #2
johann
Moderator Emeritus
johann's Avatar
Garage: BMW E39 M5, Carbon black
There are many grades of throttle steering from just balancing the car to drift through corners very wide with smoking tires.
IMO, if you are going fast on a track or twisty road you need to balance the car with throttle. Therefore DSC needs to be off.
If the corners are really, really, tight you may need to drift to get around the corner. That cann also be applied for the fun factor but it is not the fastest way to take a corner.
Cheers,
/Johan
johann is offline   Reply With Quote
Old 22nd September 2001, 17:34   #3
greg
greg's Avatar
Garage: 2000 Anthracite
I agree with Johan for sure. The M5 doesn't respond real well to throttle steer, but when you're in the middle of a corner at neutral throttle (i.e., enough to maintain constant speed) you can still balance it a bit. Unfortunately you just can't really make the nose tuck in, because the balance is so tilted to understeer. A car with Dinan suspension (or other) will be more rewarding to balance with your foot.
Sports cars (at least good ones) are much more responsive - you can really adjust your line with your foot in a Porsche 911, for example.
greg is offline   Reply With Quote
How to adjust throttle cable karlcchen E34 M5 Discussion 4 18th July 2006 21:37
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 00:31
Occasional throttle hiccup? Alaris E39 M5 and E52 Z8 Discussion 42 26th July 2003 06:04
'88 M5 - Oil in throttle body air box TXVTX E28 M5 Discussion 0 12th February 2002 01:14
chip vs stock throttle behavior BMHJ E34 M5 Discussion 4 31st July 2000 18:07
