Control and Thrust Arm Bushings - BMW M5 Forum and M6 Forums
Old 28th February 2007, 20:37   #1
fiftyfive
Garage: '00 M5 Black/Caramel '99 M3 Coupe Yellow
Mr. Dumb Guy asks: Which are the control and thrust arm bushings? For that matter, which is the control arm and which is the thrust arm?
fiftyfive is offline   Reply With Quote
Old 28th February 2007, 20:41   #2
Djonny
Djonny's Avatar
Garage: M5 Silverstone
Thrust arm is item number 5 on the picture and the thrust arm bushing is item number 6. I honestly can´t be sure which is the control arm but guessing it´s number 12 since it´s the "other" arm on that pic I might be wrong about that though...!
´99 M5 Silverstone Metallic
Djonny is offline   Reply With Quote
Old 28th February 2007, 20:46   #3
fiftyfive
Thanks Djonny. Apart from the thrust are bushing, looks like either arm needs replacement if their bushings/ball joints go bad?
Old 28th February 2007, 20:59   #4
Djonny
Djonny's Avatar
Well there is a thread here somewhere about those bushings and how you can buy the whole arm with bushings for some 130 dollars which I think is very cheap. I´ve already bought the X5 bushings as they fit perfectly and are said to be beefier. But if you use the search button and write "thrust arm bushing" then you´ll get a sh**load of posts about this very problem hope you find all the info you might need.
Ps. Take a look at post number 13 in this thread.
X5 Thrust arm bushings
Old 28th February 2007, 21:47   #5
m5 deamon
m5 deamon's Avatar
Garage: 2003 e39 m5 carbon black on black sport interior
fiftyfive,
the thrust arm is number 5 ing the diagram and the bushing is number 6. i am positive about that. by the way what simptoms you haveing that you are replaceing the arm and bushing. the bushing is servicable
m5 deamon is offline   Reply With Quote
Old 28th February 2007, 21:54   #6
fiftyfive
Here's a link to a beastpower page that shows arms and bushings, courtesy of Djohnny's lead. Simplified but illustrative.
http://www.beastpower.com/Merchant2/...Store_Code=BMI
Any tricks for pressing in new thrust arm bushings? RescueHercM5 E39 M5 and E52 Z8 Discussion 7 15th February 2007 02:55
PowerFlex Thrust Arm bushes for E34 vchachanidze E34 M5 Discussion 6 19th August 2005 13:16
Replacing Thrust Arm Bushings baf3472 E39 M5 and E52 Z8 Discussion 8 13th August 2005 20:09
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
