Work in progress [540i 4.9 Kompressor buildstory]
1 reading
369K views 1.1K replies 87 participants last post by  Ballard540
#1 ·
Finally I see computer arms in action....
#2 ·
Very cool, I'd suggest having a good radius on the metarial that wasn't cut.
Must be installing some Darton material.
#5 ·
catchuk said:
is that your 540i block that your rebuilding? Im curious as to what other internal mods you have planned. Who's your builder?
VAC Motorsports in Philly.... CP pistons , Arrow Rods , S62 crank , Heads have been done , oversized valves, Cams have been tweeked a little(Elgin Cams),Darton Sleeves..... ICS Performance is putting it all together in Stamford CT. Stoptech Brakes, Bistein Pss9s , Clutchmaster clutch & flywheel set up, Diff's online Differential(338 lsd), Michelin PS2s , Walbro High Flow fuel pump with a booster pump in line, 680cc Precision injectors, Custom Fuel rails, Custom InterCooler by 666 Fabrication , T-Trim Blower by Vortech, Zionsville Super Duty Cooling Radiator Kit , Custom Oil Cooler by ICS, All new Fuel lines SS braided , UUC short shift kit , Boostlogic Fuel/Boost gauge , AEM A/F wideband , Oil temp gauge , Laser Pro Park Laser jamming system , Beltronics Pro X-65 Radar detector..... Tuning By Nick Glantis of Technique Tuning(He will be flying to Ct. to tune it in person) Also Stereo enhanched by Bavsoundwerks
#11 ·
T-TRIM 540i said:
I really have no Idea but , before we started we had 440 RWH and 391 RWTQ SAE with a V2 Vortech @ 7 PSI.... 600 WHP ??? We will see....
Should be doable! If you are doubling your boost, the calculated gain would put you near 600 whp starting from a baseline of 440 whp/7 psi. I don't remember what injector set up you have, but the key will be feeding that monster lots of the good stuff.. mmmmmm
:cheers:
Dave
#12 ·
:cheers:
Dave
I think Precision 680cc injectors with a Walbro High Flow in tank pump with a Kenne Bell Boost - A - pump in line capable of delivering 330 L of Fuel , I again only think this will be the set up as the tuning is all up to George and Nick G .
#16 ·
kees said:
Very cool. Do you have dynosheets and specs of your 'old' setup?
If you could add some more pictures and details then I'll add a link for this thread to the FAQ thread at the top of the forum.
Here is the last "old Dyno" before we started to go crazy, it actually compares before ICS added the SS headers and 666 Fabrication Intercooler and Tune to the after SS headers , 666 Fabrication Intercooler , new crank pulley and Tune..... Plus pictures of the car's exterior which will remain the same and a single shot of the engine bay which will look a bit different when finished this go around... As soon as Chris at VAC Motorsports sends me the promissed photos I will post them...
#17 ·
:thumbsup: If you want to really go stealth, maybe you should re-badge her with a '528'...:hihi:
Dave
#18 ·
Dave
Hey , I just might do that a 528 with the mean sound of SS Headers...:biggrinbounce: BTW The "Doctor" Mr. Elgin of Elgin Cams in California is shipping my newly finesed cams to VAC today,,, Unfortunately I need a few parts for the Vibration Dampening system that have to be flown out of Gemany ,7-10 days arrival time.... But , there is a light shinning I can see it, i just wonder should I walk to the light to find more inner patience....:confused3
#20 ·
I love it. Yours is really gonna be one of a kind. Must... be.... patient.... masterpiece.... can't.... be..... rushed.....
D
#21 ·
That is going to be one bad-*** mofo!lovelove
#22 ·
Jimmy, not to hijack the thread, but I just checked out your photos.. gorgeous car!
D
#23 ·
wilsodh said:
David - who's doing the sleave work?
Dave
VAC MOTORSPORTS did all of the bottom end machine work which included making room for the S62 crank bearing to fit , heads were done by someone George knows in CT. that does work for some of the Nascar crowd and the "Doctor" Mr. Dimitri Elgin did the Cams... VAC MOTORSPORTS will be putting the whole engine together for me after they receive all the parts... mmmmmm
