Work in progress [540i 4.9 Kompressor buildstory] - Page 99 - BMW M5 Forum and M6 Forums
Like Tree58Likes
Old 4th June 2012, 03:38   #981
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
Oh, to who ever is rebuilding the engine, might I suggest getting a can of copper coat spray from Fel-Pro and coat both sides of the gaskets for better sealing. I have been using this stuff on these types of head gaskets with no failures.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline   Reply With Quote
Old 23rd June 2012, 02:58   #982
jvfff
jvfff's Avatar
Garage: Black 1998 BMW 540i 6 speed
I'm about to start building an intercooler for my S/Ced 540i and researching what I can fit behind the bumper.
What model PWR Aero 2 intercooler is used in this build?
Thanks!
jvfff is offline   Reply With Quote
Old 23rd June 2012, 03:10   #983
E38 Prototype
Garage: 2000 740i Sport Anthracite Metallic
Umm.. this means you have another build thread?
Built 98 DSM
Project e38 - sold
00' XJR
E38 Prototype is offline   Reply With Quote
Old 20th August 2012, 06:41   #984
MadMaxD
MadMaxD's Avatar
Garage: X5 4.6iS Estoril Blue
Originally Posted by T-TRIM 540i View Post
So we will see here soon on what I have hidden from view in the bowels of my motor whether 92MM ,93MM or 94MM pistons.Awfully confusing at times.
This is the part # of one of the the gaskets I received today from VAC.I knew my crank was an Alpina crank so hopefully these gaskets are the ones...
I am going to flush the cooling system a few times and replace the antifreeze this week.Then I am going to drain the oil out and put the Accusump back in line and then drain it as well.Then all new oil.
Then I will feel OK to drive the car the 92 miles to Tim's at a leisurely pace to tear the car apart.
Part Cross-reference
RealOEM.com Home
Language:
Part 11127519410 (CYL.HEAD GASKET) was found on the following vehicles:
E52: Details on E52
E52 ALPINA V8 Roadster
E53: Details n E53
E53 X5 4.6is SUV
Real quick, hate to step in on an old thread, but I had a quick question for you. I'm currently building my X5 4.6iS, and you mentioned the Alpina crank, which is a shorter stroke than the S62 crank (and from what I remember, is the same as what's in my truck). Did you end up using the S62 crank or Alpina?
MadMaxD is offline   Reply With Quote
Old 3rd November 2012, 19:11   #985
Ballard540
Garage: 2003 540i M sport (slightly moded)
Hey guys. Sorry for the lond delay in response I have been busy and work takes most of my time. SO.... updates:
I have the car put back together and running have for months now, and it does very well. When going into the engine I had several head stud holes stripped, blown head gasket, stretched studs, and a few other minor issues. Never the less It's going again.
Since then I have had a couple more over heating problems, and now it needs a new clutch.
The over heating problem I solved by using a VSL M5 radiator, and an M60 water pump to eliminate the 240 degree head temp, now I run 202 on the crossover tube between the heads, which is where I placed my PLX sensor and my 4 wire DME temp sensor. I also added two Derale electric fans and fabricated my own aluminum shroud and mounted all this neatly. I have a few pictures I will find and post.
The clutch I have decided to go with is a UUC Dual Disk single mass set up, which I have been told they will be releasing soon (hopefully).
At the same time I replace the clutch, I am also going back into the engine, relacing bearings and all new gaskets along with putting titanium thread inserts for the head studs to make room for future plans..
After I do this I will assembly the engine back as is with the Vortech unit run it to make sure all is well, then I am building a custom manifold and mounting a Kenne Bell twin screw compressor atop this beast, and pushing slightly more boost and pushing us up to about 950 crank HP.
to answer a few questions, this engine does have an alpina crank since alpina used the single timing chain and it was going to be easier to make work. BUT, the alpina has the exact same stroke as the S62. So either you want to use will work.
And yes the injectors are from 5O performance, 779cc flow at 4 bar.
In the mean time this has been our other e39 project..
Ballard540 is offline   Reply With Quote
The Following User Says Thank You to Ballard540 For This Useful Post:
herrubermensch (3rd November 2012)
Old 3rd November 2012, 19:17   #986
Ballard540
Sorry about not posting the injector part numbers. Here it is
Old 3rd November 2012, 23:41   #987
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
Is that a carburetor? C'mon, even nascar uses EFI, now.
mattmartindrift is online now   Reply With Quote
Old 3rd November 2012, 23:56   #988
Ballard540
Yea that's a carb lol it was only to break the engine in while his throttle body was being made. It's now running a stand alone.
Here is how it looks now, of course you cant see the throttle body now..
Old 4th November 2012, 01:02   #989
T-TRIM 540i
Garage: SC'd titanium Silver 2003 540i sport
I am so glad that Eric ended up with my car.
T-TRIM 540i is offline   Reply With Quote
Old 4th November 2012, 01:48   #990
rao
Garage: Silver 540i
Looks good
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is offline   Reply With Quote
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
Car Back in Safe Hands - Work in Progress FinalEditionE34M5 E34 M5 Discussion 10 13th September 2004 02:30
Stay away from RMS because Osh is a conman !! Black M5 E39 M5 and E52 Z8 Discussion 245 12th June 2004 20:53
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
