Work in progress [540i 4.9 Kompressor buildstory] - Page 91 - BMW M5 Forum and M6 Forums
Like Tree58Likes
Old 2nd January 2011, 16:20   #901
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
I always use Loctite medium for the chain guide bolts.
They have the tendency to come loose even tightened with the correct torque.
The nut of the cam oil guides falls right from the head through the oil return bores in the block into the oil pan,so usually no damage can occure from that.
Do you have more pics of the chain guides?
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 2nd January 2011, 16:55   #902
T-TRIM 540i
Garage: SC'd titanium Silver 2003 540i sport
Loctite Blue is what I suggested and will suggest again tomorrow.The nuts that hold the Impulse Sending Wheel in place is also a place where I suggested Loctite to be used as I have had them back out before in a previous fiasco.I assumed that since the bolt and nut seemed un-mangled that they just dropped and sat in the bottom of the pan,thank the car gods for that small favor.
No more pictures as of yet.I am going to ask them to shoot a few for me Monday.
T-TRIM 540i is offline   Reply With Quote
Old 2nd January 2011, 17:06   #903
vantaam5
vantaam5's Avatar
Also Loctite medium for the bolts that hold the cam sprockets is a must!
Also get part number 07 58 9 062 376 it is Drei Bond 1209 liquid sealant.
Best liquid sealant stuff out there,IMO..
I use it for all gaskets of the timing covers,oil pan gaskets,water pump gaskets,.......
Question is,did the chain guide break because the bolt backed out,or did the bolt back out because the guide broke?
This is why I was asking for more pics...
Old 2nd January 2011, 18:58   #904
T-TRIM 540i
That is a good point.I do know that all was brand new when the motor was put together by VAC.Timing chain, guide,Timing chain tensioner,cam chains,Cam timing chain tensioner ETC...
I appreciate your help....
Old 8th January 2011, 03:13   #905
T-TRIM 540i
Just got these images of my Mess
MOV04300.mp4 video by BMW_540i_2003 - Photobucket
At least some of the parts to put it back together are there as well.We are not using the Victor Reinz head gasket set...
I go to Wilmington on Monday to visit my cousin,drop off some Sarouk carpets to be cleaned and then go see the mess and give them a check for what they have done already.Oh yeah and as well give them the GoodRidge oil line that contains the accusump " T ".
The Following User Says Thank You to T-TRIM 540i For This Useful Post:
Mike S. (8th January 2011)
Old 11th January 2011, 18:42   #906
T-TRIM 540i
Damn if we did not have a Snow-Ice storm which kept me from going to Wilmington to see the car and my Cousin.Snow-Ice already gone.
Well today I asked Dan to snap a few pictures of the Sleeve job that was done on my car and he said he would like to ,but the motor is back together.This is much to my surprise.It seems that Tim went in Saturday and took advantage of the snow-ice storm and worked yesterday to get the motor back together.
Progress made and he did use Medium Loctite on all interior motor bolts.
So most likely in a couple of weeks the car will be all the way together and run through the first heat cycle and then recheck the head bolts with the torque wrench.Then the valve covers go back on and I go write him a check and pick up the car...
The Following 4 Users Say Thank You to T-TRIM 540i For This Useful Post:
gsfent (11th January 2011), herrubermensch (11th January 2011), mattmartindrift (11th January 2011), Mike S. (11th January 2011)
Old 11th January 2011, 18:58   #907
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
good to hear!
break a leg!
mattmartindrift is online now   Reply With Quote
Old 11th January 2011, 19:13   #908
vantaam5
vantaam5's Avatar
Good news!
Old 11th January 2011, 19:13   #909
tacoma330ci
Company Representative for RK Autowerks
Garage: 2003 E39 M5 TiAg
Sales Feedback: (3)
Crossing fingers that this is the last time you have to have engine opened up...
tacoma330ci is offline   Reply With Quote
Old 11th January 2011, 23:08   #910
T-TRIM 540i
The motor while in my possession will not have any necessity to be dealt with as a problem.Tim is a Smart , HONEST person who knows his M62TU motors.He is not some Forced Induction shop , but instead a shop that has grown to be a well respected business in Wilmington ,N.C. He went way out of his way to help me out in this less than desirable situation.I am fully confident that the motor will be 100% and I will definitely put it to the test before heading to Florida with the car.
I will put up videos , not guaranteeing the quality , when I get the car running....
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
Car Back in Safe Hands - Work in Progress FinalEditionE34M5 E34 M5 Discussion 10 13th September 2004 02:30
Stay away from RMS because Osh is a conman !! Black M5 E39 M5 and E52 Z8 Discussion 245 12th June 2004 20:53
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
