Originally Posted by vantaam5
Shouldn't the S62 head gasket fit on the M62 block?
Did read somewhere many B10s use this head gasket as upgrade
If so,it also has 94mm bore....
And I think can handle a bit more than the M62 head gasket...
That is what I said , but the Sub Ling up there at VAC ,first would not tell me the BMW part numbers he was sending me as " it was a secret" .WTF I only spent almost 20K with the damn shop on that damn motor , a secret,HUH? Everyone knows that the Victor Reinz company makes all gaskets for BMW and Mercedes,I believe..If he had told me the parts number I would have told him that if what they told me , the engine builder VAC , was in fact true that the M62 gaskets would not work with 94mm pistons.That is what you get when you deal with a "Salesman" rather than someone who understands a motor.
As far as I know the S62 gasket should fit,but I am not a mechanic just a part time mechanic out of necessity.
Hopefully today Tony, the owner of VAC will figure out WTF is going on as they did build the motor and got paid handsomely and on time for ICS's mistakes by me....
Of Course, I will see what the hell is going on when we pop the motor open ,but I wanted all the parts and pieces there at the shop when we tear the motor apart as I plan on having it back together the same day , late in the day of course.
I also asked why the failure to begin with at only one Bar boost and just like someone told me earlier ( That does not work for VAC ) they mentioned the tune could have caused the failure.NOT LIKELY.....More likely the pinheads did not check the torque on the heads after the initial heat cycle thus why I found three studs less than the torque #'s they should have been when I pulled the covers off and put the torque wrench to them....
