Work in progress [540i 4.9 Kompressor buildstory] - Page 84 - BMW M5 Forum and M6 Forums
Like Tree58Likes
Old 10th November 2010, 15:36   #831
Fart
Fart's Avatar
Garage: E36M3 GT#111 Twin Turbo
Originally Posted by T-TRIM 540i View Post
I know the OEM M62 gaskets are metal and I assume the S62 would be as well, but having never had one in my hands I can not say for sure...
Ok, the S50B30 one is not, its made by Elring
Fart is offline   Reply With Quote
Old 10th November 2010, 17:55   #832
T-TRIM 540i
Garage: SC'd titanium Silver 2003 540i sport
I will know what I am getting in a day or so.
My friend in Wilmington agreed to help out as he has all the tools to do the timing correctly when the motor goes back together . I can tear it down no problem and get it back together no problem ,but getting the Vanos and Cam timing correct HMMMMM I bow to someone who has done it before again and again.There is a machine shop close by to check the heads deck out as well.
I just hope that we see evidence of where the leak is in all actuality....
T-TRIM 540i is offline   Reply With Quote
Old 11th November 2010, 05:03   #833
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
Can I suggest that you grab a good paint pen and mark the camshaft to cam cap so you align it up easier?
I grab two or three colors so I can also mark the chain.
I mark everything at TDC then move it 45degree so all the valves miss the pistons if cams should turn.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline   Reply With Quote
Old 11th November 2010, 05:40   #834
OJwerks
Garage: E39 540i and a few others.
i'd kill to see a full HD video of your car running through a canyon or racing around a track...!
2001 BMW 540i E39
Lots of mods and more to come...
under construcion...http://forums.bimmerforums.com/forum...1#post16144513
OJwerks is offline   Reply With Quote
Old 11th November 2010, 11:41   #835
T-TRIM 540i
ABSOLUTELY.Thanksfor the tid bit of knowledge as I said I need all the help I can get....
Old 11th November 2010, 12:54   #836
Fart
Fart's Avatar
You should not be too scared, I did a HG change on my S50B30, without any previous experience. Just take your time, mark all the nuts and bolts, set the crank to TDC and then there are markings on the Cams for the same purpose. If you machine the heads then you might need to do some valve adjustments again. Just remember to mark the valve adjustment shims with numbers so they go in the same place again.
The hardes thing was to time in the cams/vanos and adjsust the valves. But I managed so you should
Old 12th November 2010, 01:20   #837
T-TRIM 540i
The hardest thing was to time in the cams/vanos and adjsust the valves. But I managed so you should
I have done everything else in this car over taking the motor apart is no problem .It is the putting back the Cams,Vanos and getting the timing correct that I had a problem with ,but since my friend ( 20 year Master tech with BMW that now owns his own shop ) said he would be happy to help and supply the specialty tools I am cool...
EXCEPT, I got the head gasket from VAC today and they are not correct as they are M62 head gaskets period.Victor Heinz made ,but they are the makers of the OEM gaskets for BMW in Germany.SO I called Tony and asked him to investigate what the heck as far as I know I have 94mm pistons in the car and M62 is 92mm pistons.We did have the problems with ICS not knowing their *** from a hole in the ground which cost me another 7K to change out the S62 crank , put the Alpina 4.6L crank in and rebalanced everything,but I can not see them,VAC, pulling the already honed Darton Sleeves out and pushing in new ones and putting in 92mm pistons.
One point to be fair it was not Tony nor Paul that sent me the head gasket,but the sub ling after I explained that I did understand I had the 94MM pistons still intact and standard M62 gaskets would not work....I have the bill sitting right here ,unfortunately....
BUT , we will see as the engine is coming apart and pictures will be of course taken.....
Old 12th November 2010, 01:30   #838
T-TRIM 540i
Originally Posted by ojwerks View Post
i'd kill to see a full hd video of your car running through a canyon or racing around a track...!
so would i......
Old 12th November 2010, 12:59   #839
Fart
Fart's Avatar
Jesus,, what a nightmare..
Old 12th November 2010, 13:09   #840
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Shouldn't the S62 head gasket fit on the M62 block?
Did read somewhere many B10s use this head gasket as upgrade
If so,it also has 94mm bore....
And I think can handle a bit more than the M62 head gasket...
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
Car Back in Safe Hands - Work in Progress FinalEditionE34M5 E34 M5 Discussion 10 13th September 2004 02:30
Stay away from RMS because Osh is a conman !! Black M5 E39 M5 and E52 Z8 Discussion 245 12th June 2004 20:53
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
