9th November 2010, 18:53
#824
Originally Posted by E38 Prototype
T-Trim, Do you happen to know what the Surface RA was of the block and head after machining? I ask because in my turbo world it needs to be as smooth as possible, with the stock headgaskets (our 4.4l are metal correct?) To get a perfect seal under boost.
Also, The normal ARP's tend to not hold as well and we use A1 head studs.
Just a couple notes from the turbo import world
I have no clue what the RA value was when VAC put the motor together.
Yes the BMW OEM head gaskets are metal.
I have a call into Paul at VAC to find out a few facts ,he has been real good at helping if I talk to him directly.
My bore is 94mm so I am sure I have the S62 gaskets in there,maybe,not sure ,that is why I have a call into Paul...I emailed Tony,but that can take awhile....
