I know it is all relative but , I was freezing my rear off in the 18 F temps. I should never of lived in the Caribbean for as long as I did as it ruined my cold weather tolerance level....
__________________ 2003 M5 "The Matte Black Money Pit"
ALPHA-N by EVOLVE,Power remapped-modified heads-Schrick cams-modified throttle bodies and velocity stacks-modified rods and crank-EVOLVE headers -Willans 4-point harness -CAI with custom built MAF delete tubes fed through fog light covers -lighter oem flywheel-Sachs performance clutch-clutch stop-Drexler differential stock ratio-electric fan with control unit-545i SSK-HEL braided teflon brake lines-IATS reloction-Bilstein PSS9-HD sway bar links-M3 swaybar brackets rear-CF bonnet with vents-subframe reinforcement-40mm wider fenders front and 25mm rear-aluminium ///M pedals and foot rest-CF roundels-LED AE-foglight delete-AP BBK kit 6piston calipers front-CF strut bar front-full suspension rebuild-camber plates with uniballs front-Dinan sway bar-illuminated inner door handles-Alcantara roof liner-M-Audio system- Hamann HM2 10x19" wheels 275/30 front and 295/30 rear
Carbon black/black sport interior/titanium trim,37k miles,bone stock -20cm of the trunk and quarter panels missing...
-rebuild in winter 2011/2012
-"submarine edition",a bit boost and some M5 parts...
wow, bump for being probably the longest thread ive ever seen. I also thought I had the coolest 540... 8-( I love the idea of this build though. No one ever mods 540's. I cant wait to see some vids.
Excellent thread. TOTALLY AWESOME car. Sir, you have the mental toughness of no one I have read about that is not a fictional character. To get through your illness and keep your life and all it entails on track shows you are blessed. One item I did not see, how did you get shot with a .45 (and live)? If you don't want to answer no offense would be taken. Here is to an even keeled twenty-ten!
