Work in progress [540i 4.9 Kompressor buildstory] - Page 40 - BMW M5 Forum and M6 Forums
Like Tree58Likes
Old 4th August 2009, 17:11   #391
T-TRIM 540i
Garage: SC'd titanium Silver 2003 540i sport
Another fact is that when the guy in Australia gets done with his version of an aftercooler and see it's results that will automatically give me back 3 1/2 pounds of boost as the air to air intercooler because of Volumetric physics is inefficient a bit...That is like Dave says I will never be done but , I will never let it out of my sight again either I will fly Mr. X in a lot closer and be there myself. That is a long ways off as I am having fun driving at the moment and re-learning the car.....I just overnighted the paper work to Florida to the Palm Beach County Tax Collector.14- 21 days they say....
T-TRIM 540i is offline   Reply With Quote
Old 4th August 2009, 17:38   #392
wilsodh
wilsodh's Avatar
Originally Posted by T-TRIM 540i View Post
The 8 rib pulley on the supercharger and the 8 rib pulley on the crank pulley are to plainly prevent slippage of the belt under strain.The crank pulley is 7 1/4 " in diameter and the supercharger pulley is 3.0" and shifting at 7K or so that spins the blower approximately at 58,362.50 RPM which is just barely overspinning the blower at maximum boost of 11.5 pounds. ( max reccommended on the V-1 T-Trim is 55,000rpm ) I had a larger crank pulley made...that gave the car almost 15 pounds of boost but , you were overspinning the blower by more than the 10% that Vortech said would be safe for that shift range.
David - do you have a handy dandy calculation for blower rpm from crank/SC pulley diameter and rpm? Looks like the 58,362.50 came from a calculator. I'd like to calculate my blower speed. I have forgotten my crank pulley diameter (I need to pester Shadowman for it) and am wondering where I am vs. the Vortech max recommended. I seem to be maxing out the V1 T-Trim, and am considering an upgrade to the V7.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
Old 4th August 2009, 17:48   #393
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Dave
Oh yeah, your car needs MORE power!!
gsfent is online now   Reply With Quote
Old 4th August 2009, 17:56   #394
wilsodh
wilsodh's Avatar
'Boost Intoxication'.... it's a sickness Jerry...
Beware!!
Dave
Old 4th August 2009, 18:01   #395
mamsterla
mamsterla's Avatar
Garage: 2001 LMB 800 HP DA Twin - The Blue Beast
Sales Feedback: (3)
Hey Dave - if you change the blower, do you need to change any of the programming?
2001 M5 - DA Twin - The Blue Beast 800HP former PhillyM5 car
mamsterla is offline   Reply With Quote
Old 4th August 2009, 18:30   #396
gsfent
gsfent's Avatar
Sales Feedback: (3)
Beware!!
Dave
I may be joining sooner than you think!!
After reading blockdoc's description of acceleration in his ESS (no headers) car, I really can't imagine what yours feels like.
Go for it; if it is worth doing, it is worth doing to excess!!
Old 4th August 2009, 18:32   #397
gsfent
gsfent's Avatar
Sales Feedback: (3)
Hey, if you and Dave get together, will the combined acceleration affect the rotational axis of the earth???
Old 4th August 2009, 18:38   #398
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #24 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (4)
Only if they are traveling in the same direction
Kelster is offline   Reply With Quote
The Following User Says Thank You to Kelster For This Useful Post:
gsfent (4th August 2009)
Old 4th August 2009, 18:45   #399
wilsodh
wilsodh's Avatar
Keeping the same pulleys, I think I'd just be seeing a little more of what was intended. I don't anticipate any recalibration would be needed. As you know, I'm interested in dumping my MAFs, so a re-tune looks to be on the horizon in any case.
Yeah, what I always say! (And what the little woman pushes back on! )
Dave
Old 4th August 2009, 18:56   #400
T-TRIM 540i
Dave
Go to the Vortech website and go to the support area and there is a calculator there for the V-1 blower. You enter diameters of the pulleys and your shift rpm and push a tab and you have the speed of the impeller calculated. The V-7 is a monster 4" outlet , there at least two M62 motors that are going through the process with that blower as well as Carmen's car that D/A built , as the engine evidently crapped out on him ( that is what I heard ) and he took it on the chin and said well lets start over and it is now at ACEperformance being done in spectactular fashion.If Mr. X had not wanted my car at AA it would of been at ACE.....It is a monster blower even louder than the V-1 as it is staright gears as well.....
The Following User Says Thank You to T-TRIM 540i For This Useful Post:
wilsodh (4th August 2009)
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
Car Back in Safe Hands - Work in Progress FinalEditionE34M5 E34 M5 Discussion 10 13th September 2004 02:30
Stay away from RMS because Osh is a conman !! Black M5 E39 M5 and E52 Z8 Discussion 245 12th June 2004 20:53
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
