What's the best way to get a beast on 4 jack stands?
Was going to send my rims to get refinished for spring and I figured I might as well do them all at once.
Respect a mans car, a man respects you. "In every detail, the M5 was a poster child of the M philosophy: superb driving dynamics, luxurious interior and above all, uncompromised performance." - BMW.ca regarding the E39 M5
www.bmwtips has some good general info. HOWEVER, Our cars do not have the block in the center structural member like the 540's in the picture do.
In the front I've been able to use a combination of slim ramps, then jacking (with a pad on the jack) right next to the jacking points on the frame. Then you can use the jackstands on the proper frame jacking points.
In the rear, the diff housing seems to work for the jack.
This certainly is the worst car I've ever tried to put 4 jackstands under.
There's a thread on this - it's easy if you have two jacks. If not, then it's a challenge. If you have one garage hydraulic jack, then run down to Canadian Tire and get a second jack - their mechanical screw-jack will work fine for the second one.
At the front, there's a round pick up point at the center front near the oil drain hatch. Lift one side of the car to make clearance for the hydraulic jack under the center and then lift there. Set the front outboard jack points on stands.
At the rear, your choices are to lift it on the diff (which I've never done) or just lift from one side (the E39 has a remarkably stiff body) and then put the side opposite the jack onto a stand. If you have a mechanical jack, pull the hydraulic jack and switch to the mechanical jack to level the chassis and you're done.
I have to say, there are times when having a set of snow tires on rims seems a real blessing.
worst come to worst, lift the car up near the ball joints. that is a strong area, most people are afraid to plop a jack under the beast in places where there is not rubber molding.
1/5/07 - Just finished hardwiring V1
Next: SSK
Success is the ability to go from one failure to another with no loss of enthusiasm.
I'm assuming he's referring to driving the front wheels up on the 2x6's to gain clearance so a jack can then slide under the front of the car. Then, the front can be jacked up by the central jack point under the front of the car.
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
I wasn't sure t he E39 had the center lift point in the front like the E46 does.
Thank you.
'02 M5 Sterling Gray / Black
UUC EVO3 w/DSSR
Supersprint Cat Back Exhaust
