Originally Posted by mfizza
very nice, how much? Is it easy to install?
Install is VERY easy. There is a plastic frame at the base leather boot that just snaps in and out of the center console easily.
The only issue I can see is if you have the OEM shift knob that has the leather attached to the boot itself. I used to have that, but have since changed knobs a few times. If you're planning to use your OEM knob that was connected the the leather boot, you will have to cut the leather where the base of the knob meets the leather shift boot.
One more tip, if you have never removed your original shift knob, you may be in for a treat - you will have to pull straight up with a decent amount of force to get it off. Watch out though, once it breaks loose you don't want to have all of that force hitting you on the chin Once I get the new boot from LeatherZ I will post pictures, but here is what my setup will be -
