Old 18th February 2007, 03:03   #1
c4m5
Garage: 2000 Alpine White, Silverstone Interior, no badges, open Brake Ducts. White calipers.
Radio stops working ?
My Radio/CD/NAV screen will stop working and then minutes later come back on, if I turn it off&on after it stops working it will work again for a short while??? Whats up with that? The BMW installed phone (CPT 7000) also does not work any longer with the steering wheel controls or hands free? Are these problems related?
D. Guilburt: 12/99 Build, 2000 Alpine White, Silverstone Sport Interior, 2001 Instrument Cluster, Dinan Short Shifter, Dinan 17mm Rear Anti Roll Bar, Floating Front Brake Rotor's, Open Brake Ducts, White Calipers, Michelin PS2's, MKIV Navigation, BMW Bluetooth HF VA Phone, No Exterior Badging, Valentine One, OEM 1st Aid Kit, Stealth Bulbs, Powerchip Software
c4m5 is offline
Old 18th February 2007, 06:17   #2
LFC09
LFC09's Avatar
Garage: CarbonBlack E39 M5
can you please clarify is it just the screen that doesn't work, or do you lose all audio output related to nav phone etc?
2002 M5 Carbon Black
Black/Grey leather
Brushed Aluminium trim
AiB 3.0 angel eyes
AiB xenon match fogs
BMW 545 shifter
Dinan rear sway bar
TCD rear sway bar brackets
X5 4.8 thrust arm bushings
Bimmernav Bluetooth upgrade
phone cradle V3xx modified
Solaris invisi-bulbs
MkIV Nav V31 custom splash
ex 1959 FC Holden sedan
LFC09 is offline
Old 18th February 2007, 06:31   #3
c4m5
I lose all the audio and the screen, the phone is a separate issue (I think) it works if you take it out of the cradle just not with the steering wheel controls or hands free speaker phone.
c4m5 is offline
Old 18th February 2007, 09:06   #4
Trini7919
Garage: BMW M5 Dark Blue
My 2001 m5 does the same thing since it started snowing if find out any thing let me know .
Trini7919 is offline
Old 18th February 2007, 16:06   #5
SoCalJD
SoCalJD's Avatar
Garage: 2002 M5 Bluewater
Mine does the same thing. In our last rally, the Nav screen shut down, along with the radio. Now that I think about it, it happened after our last rally too. Both times after a lot of hard driving. Of course, when I bring it to the shop it's working fine, so they don't want to "fix what ain't broke".
"The whole world was astonished and followed The Beast." Rev 13:3
SoCalJD is offline
Old 18th February 2007, 17:20   #6
suprfknman
suprfknman's Avatar
Garage: 2001 BMW M5 BLACK
I just lose the audio here and there but the nav screen stays. It will usually come back on its own or if I turn it off and then on again it will come back.
Will
01 BLK/BLK
05 Toyota Sequoia (for the winter)
04 S55 AMG
05 S4 Cab
91 JZA70 twin turbo supra RHD
suprfknman is offline
Old 18th February 2007, 19:48   #7
mricorp
mricorp's Avatar
Garage: 2003 BMW M5 LeMans Blue
I had that problem a few years ago. Something that had to do witht he nav system in the trunk I believe. The unit was replaced and I never had the problem again.
Rob
2009 MB E63
2003 E39 LeMans Blue M5 (Sold)
2006 E60 Alpine White M5 (Sold)
2008 Porsche 997 Turbo
1987 Porsche 930 Turbo
2005 Ford Excursion EB Diesel
1990 Ford Mustang 5.0 LX (331 CID)
1986 Ford Mustang 5.0 LX
2001 Ford F350
2008 MB GL450
2006 Porsche 997 GT3 Cup
mricorp is offline
Old 18th February 2007, 20:01   #8
ard
ard's Avatar
All audio is passed through the radio, amp and nav unit in the trunk. The I-bus handles control signals for radio, nav and phone....
There are a variety of wierd audio issues that can be caused by component failure OR BAD/LOOSE CONNECTIONS in any one of these modules.
Try disconnecting all these devices and reconnedting- all it takes is a pin that has a spot of corrosion, or has wiggled loose. Disconnect and reconnect 3-4 time, maybe 'scrubbing' the contacts with this action.
Worth a shot before a dealer visit.
ard is offline
Old 18th February 2007, 20:09   #9
e39dream
e39dream's Avatar
Garage: jet black 1998 528i sport
Hi guys- I am a newb here but I spend alot of time on BF.c and alot of times gremlins having to do with the radio are a sign of a failing battery.
http://www.bmwtips.com/tipsntricks/t...es/battery.htm
Further, if you start to note other symptoms such as steering wheel not moving on start up (not moving to memory settings), problems with the visor vanity lights, or dash cluster lights your ignition switch is likely failing.
193 horses of M52 powered goodness since 1998.
http://i28.photobucket.com/albums/c2...s/CIMG1500.jpg
e39dream is offline
Old 19th February 2007, 01:08   #10
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
Could be a thermal cutout of the DSP amp if its happening after spirited driving.. exhaust heats up and heat radiates into the boot (trunk). When I am at track days I leave the access panel open as to try and disipate the heat 'somewhat'
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Questions on ipod and digital radio in the UK Webby E60 M5 and E61 M5 Touring Discussion 0 9th September 2006 01:31
Troubleshooting radio? Ag Surfer E39 M5 and E52 Z8 Discussion 12 23rd June 2006 06:18
XM Radio Integration?? gtessier E39 M5 and E52 Z8 Discussion 9 6th June 2006 21:38
Radio Annoyances (MKIII) HenryHank E39 M5 and E52 Z8 Discussion 3 21st March 2006 20:34
Climate control stops working!! BostonRocket E39 M5 and E52 Z8 Discussion 8 28th October 2001 04:11
Page generated in 0.14028 seconds with 11 queries
