Old 17th February 2007, 23:59   #1
phid_bombadier
phid_bombadier's Avatar
Garage: '01 M5 - Silverstone
Fuel Filter Replacement
There are some instructions floating around but here are some pics as well.
Quick list:
1) jack up and support car
2) pull fuse 54 in trunk fuse panel to disable fuel pump
3) start car a couple of times to depressurize system
4) Remove under panel beneath drivers side door (half a dozen plastic retainers and 2x 10mm nuts and 5 x 8mm screws)
5) Use release schrader valve to release even more pressure/fuel (I didn't do this step)
6) Remove filter clamps (2x10mm bolts)
7) With a catch pan ready, Remove rear filter quick disconnect (pull plastic part into metal sleeve and pull off connector) Cap with plastic cap from new filter
8) Remove front 2 quick disconnects and vaccume line
9) Using an adjustable crescent wrench and a 19mm combo wrench remove regulator from threaded end of old filter
10) replace or transfer copper crush washer to new filter and attach regulator
11) Transfer filter clamps, and reinstall.
12) turn key to position 2 and purge air using the schrader valve on the regulator
13) start car and let idle smooth out
Here are some pics attached.
HTHs,
--Mike
phid_bombadier is offline
The Following 3 Users Say Thank You to phid_bombadier For This Useful Post:
-BEASTMW- (11th April 2009), El Diablo (31st October 2009), mooch (9th April 2009)
Old 18th February 2007, 00:09   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Nice!
Thanks Mike!!
d-
DouglasABaker is offline
Old 9th April 2009, 17:35   #3
b757236
b757236's Avatar
Garage: 2003 BMW M5 Silver
What is the schrader valve? Could you better explain?
"turn key to position 2 and purge air using the schrader valve on the regulator"
Adam
2003 M5
Shark Injector (Standard Software Version)
E60 SSK
Royal Purple Syncromax Fluid
ZHP Shift Knob
ATE Super Blue Brake Fluid
Matte Blackout Grille
MyCarr LED Angel Eye upgrade
35W HID Projector Fog Lights 4500K
DDM Tuning Xenon Interior lights
2007 Mercedes GL320 CDI
Filled up with Pure Dinosaur Diesel
b757236 is offline
Old 9th April 2009, 17:55   #4
Strike
Strike's Avatar
Garage: 2002 Jet Black
A schraeder valve is what's used on your tires valve stems. There is one located at the end of the fuel rail on all FI cars to test fuel pressure or to be used to release pressure when working on the fuel system.
2002 Jet Black/Imola Red Sport
Dinan Stage I Software
K&N Filters - Brake Ducts
K40 Undetectable
AXXIS ULT pads
Black/White CF Roundels
Body Color Grills
Greyscale ///M Logos
Smoked Tails
30% Tint
Intravee II
Strike is offline
Old 9th April 2009, 18:14   #5
mooch
mooch's Avatar
Garage: 2000 Carbon Black M5
Excellent timing! I plan on doing this, replacing my pre-cat O2 sensors and swapping in an E60 545i short shifter as soon as I can get my hands on all the parts...
mooch is offline
Old 9th April 2009, 18:47   #6
graffix000
graffix000's Avatar
Garage: Jeep GC, 03 M5, 05 Yukon Denali
No need to pull the fuse and try to start the car. Just need to push the shrader valve and it does it depressurizes just the same.
Is step 12 necessary? This is the first write up where I have seen that. I did not do that when I replaced the fuel filter and didn't have any issues and started up right away with a smooth idle.
2003 Sterling Grey M5
Dinan Front Strut Brace, Rear Sway Bar & CAI
Eisenmann Race & X Pipe
UUC Evo 3 & DSSR
GC Coilovers
Confronti Shark Injection 93 Octane
Brake Duct Mod
Intravee II
Rear Wheels Up Front (275's all around)
Ultimate Pedals
V1/S1
graffix000 is offline
Old 9th April 2009, 18:57   #7
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Send a message via AIM to Lancefitzgiben
I didn't do step 12. I just got everything put back together (apart from the belly cover) and just started it up.
Lancefitzgiben is offline
Old 9th April 2009, 19:09   #8
Strike
Strike's Avatar
I can't see step 12 being necessary either. Usually when I replace a filter or pump I just turn the key to the on position for a few seconds before cranking it to make sure the pump has time to fill the lines. I would also purge it without cranking the car because if you crank it too long without fuel going into the cylinders you can possibly start to burn the pistons. Slightly, but still, why risk it.
K40 Undetectable
AXXIS ULT pads
Body Color Grills
Smoked Tails
30% Tint
Intravee II
Strike is offline
Old 9th April 2009, 21:13   #9
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
You *could* skip this step, but why? Sure you can depressurize the system using just the valve, but you'll just have to wait longer for more fuel to squirt out of here getting on your hands/garage floor, etc. By pre-depressurizing by pulling the fuse and cranking you're letting the vacuum created in the cylinders release most if not all of the 5bar pressure.
And yes step 12 is not needed. The vacuum of the cranking cylinders + the pressure of the fuel pump refills the lines in seconds.
TMcNasty is offline
Old 31st October 2009, 02:39   #10
reds2
reds2's Avatar
Garage: 01' Anthracite Beast
Is the OEm filter different? I have one that does not say Hengste or Mahle
reds2 is offline
Why you should change your fuel filter Jon@TheMShop E39 M5 and E52 Z8 Discussion 69 23rd October 2008 22:28
Ethanol based fuel...... Clem E39 M5 and E52 Z8 Discussion 28 23rd February 2006 23:52
How to avoid paying $118 for a Fuel Filter? 00m5 E39 M5 and E52 Z8 Discussion 11 29th November 2005 19:47
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 01:46
Fuel pressure 4.6 bar - is it filter, regulator or pump? DavidS E39 M5 and E52 Z8 Discussion 0 28th July 2005 15:50
Page generated in 0.14717 seconds with 12 queries
