Old 17th February 2007, 23:12   #1
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
Need feedback from AF knowledgeable on Dyno runs
Just got back from a dyno day with my club - first pulls for my car. I have the following mods that would affect HP/Mixture, etc.
IATS Relocation Kit
100 Cell Cats from Evosport
SS X Pipe
Eisenmann Race Exhaust
My MAFS are fairly fresh (10k miles or so), fresh plugs, 10k on air filters, etc. The numbers as a whole looked pretty good to me, 332 HP with correction, 332 TQ with correction. The part that concerns me is the AF Mixture. It was about 13.8 and definetley on the high side. I was thinking it could be a number of things:
1. O2 Sensors need replacement. To the best of my knowledge they have never been done - sitting at 65k miles
2. Software maps may be off because of higher flow of cats, x pipe and exhaust
3. Dirty MAF's
Any other suggestions? At the end of the run the AF seems to come back in line. Below are 2 graphs that I pulled with SAE correction.
Thanks for the help.
p.s. On a positive note, the TQ band looks BIG and FLAT. Lots of power at 2k all the way to 5500 before it falls below 300.
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
Old 17th February 2007, 23:32   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
the other potential source for error was the shop's afr sensor too, unless they plugged into the 02 sensor pre cat, those numbers have potential for error.
Did other car's at the dyno day have more 'normal' looking afr's?
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 18th February 2007, 00:48   #3
TiSiBeast
TiSiBeast's Avatar
Yes, the other cars that I saw were pretty much in line. My buddy's Cobra ran a 475 RWHP at a 12.8 AFR. Like I said, the HP and TQ numbers actually looked pretty good to me, especially considering it was 75 degrees, 8% humidity at 1150 Ft. They just had a probe in the tail, nothing direct from the ODB or the O2 directly.
Old 18th February 2007, 05:49   #4
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
Your numbers are right on for a beast performing well. WRT A/F ratios.. there are many variables that effect this including heatsoak in the engine bay andthe resulting fuel map the engine used. Your power numbers look good.
A software tune may be the next step if you really want to maximize any gains from the CAI and exhaust. Though you can wait for other mods before doing this if desired.
Looks like you have yourself a well built engine.. enjoy!
warhaven is offline
Old 18th February 2007, 06:27   #5
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
Check out Post # 138 in this thread. You'll see where I ran an AFR well into the 13's, had it retuned to average 12.4 or so, with great results (357.6 HP). You can compare the old curves as they're on the posted chart. There's probably another 7-8 HP left above 6600 RPM as you can see from the rich AFR. YMMV.
BKH is offline
Old 18th February 2007, 20:36   #6
TiSiBeast
TiSiBeast's Avatar
Do you have a link to this thread?
Old 18th February 2007, 20:51   #7
BKH
BKH's Avatar
Sorry, here it is:
Today's CA Dyno Day Results are in
BKH is offline
Old 18th February 2007, 21:28   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
+1. I had low 12's, around 12.2 at high RPM using the tail sniffer pipe. A few hp may be left on the table, but I won't hole a piston from running too lean either.
gsfent is online now
M6 Kelleners / Schrick Cams, Active Autowerke CAM ECU, Supersprint X-Pipe & Mufflers KeithTa E60 M5 and E61 M5 Touring Discussion 73 19th January 2009 06:42
How many of you guys, read GUSTAV's article on his DINAN visit/tour............ FAST 5 E39 M5 and E52 Z8 Discussion 21 16th June 2008 18:40
Feedback on dyno results - what's wrong here? cosioboy E39 M5 and E52 Z8 Discussion 81 13th January 2007 21:27
Feedback on price for baseline dyno? dteray1 E60 M5 and E61 M5 Touring Discussion 3 21st September 2006 00:34
Feedback on lack of torque during dyno run? whatheheck E39 M5 and E52 Z8 Discussion 17 31st July 2006 21:52
Page generated in 0.15540 seconds with 12 queries
