Old 17th February 2007, 22:46   #1
NaptownM5
Garage: 2003 M5 Lemans Blue
Opinions on questionable dealer service codes?? '03 Beast
As stated in my last thread, I'm about to purchase an '03 LeMans blue Beast. Does anyone see anything in the service history below that should be of a huge worry. I question the Vane/tandem pump/electric pump leaking more than once, and then the return line from steering gear leaking, and then the suction line from oil tank to pump leaking. Of course, I dont know if this is normal for these cars. I also dont know if the dealer inspects these regularly and will replace them at the smallest leak. This car had it's engine replaced @ 19000 miles by BMW and paid for through the previous owners insurance due to water intake. These loose lines could be a result of the engine replacement, the car is otherwise in perfect shape. Thanks for any suggestions!
3241014800 Vane/tandem pump/electric pump Leaking
3241064800 Return line from steering gear to oil tank Leaking
7211042900 Seat belt height adjustment Sticking/jammed
5116331300 Drink holder, front Broken
3241074800 Suction line from oil tank to pump Leaking
5116033700 Sun visors (incl. mirror cover) Loose
5116176700 Outside mirror glass Discoloured
5145007800 Instrument panel trim, complete poor surface finish
NaptownM5 is offline
Old 17th February 2007, 23:26   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
the 'vane tandem pump' is fuel pump. There are two pumps, one that actually pressurizes and delivers fuel to the engine and one that moves fuel from one tank to the other (think of our tank like a set of saddlebags). The other oil line to tank, i'd bet that is the other Powersteering oil line, as our cars do not have engine oil tanks. The p/s lines leak, all of the time. I've probably replaced weeping hoses 3 or 4 times. The factory clamps are poor. Out of warranty, the fix is to cut off the oe clamp and use a good quality hose clamp.
Nothing worrying about the history to me.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 18th February 2007, 18:08   #3
NaptownM5
Sweet, thank you for the details. Looks like I"ll have this Beast in a week or so!
Old 18th February 2007, 18:28   #4
wilsodh
wilsodh's Avatar
Don't forget to post pictures with your announcement or you will get kicked off the board.
Good luck!
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 18th February 2007, 18:48   #5
e39dream
e39dream's Avatar
Garage: jet black 1998 528i sport
Sounds like the M5 isn't immune to the power steering hose leak either
Oil tank return- does the M5 have a remote oil filter housing like the e39 540i? If so I'd imagine the filter housing is the "tank" referred to.
193 horses of M52 powered goodness since 1998.
http://i28.photobucket.com/albums/c2...s/CIMG1500.jpg
e39dream is offline
Advice on service history codes? BLKMamba E39 M5 and E52 Z8 Discussion 4 27th January 2007 00:30
Automatic recalls & Tech Service bulletins for 03 M5's howler E39 M5 and E52 Z8 Discussion 6 17th March 2005 00:30
M5 Service codes pmarin E39 M5 and E52 Z8 Discussion 0 13th September 2004 01:05
"ORDER / PRODUCTION SUMMARY" ( Note : See First Post For Instructions ) Alan A E39 M5 and E52 Z8 Discussion 82 17th March 2002 07:50
Official BMW service, is it worth it ? jrturbo E34 M5 Discussion 2 2nd November 2000 11:24
Page generated in 0.12421 seconds with 11 queries
