I've not had my car that long (4 months). The SES light has been on/off a couple of times and I popped into my local indy BMW garage to have diagnostics done and was advised that the fault was a CPS issue on inlet bank 2 ( I had alsorts of errors codes from CPS, vanos to O2 faults - The indy advised me that these could all be caused by the CPS fault). Read this forum and inlet on bank 2 is the only CPS that is not really a D.I.Y job (just my luck). The CPS took 12 days to arrive (on back order). Had it fitted yesterday afternoon (which was a 2 hour job). All I can say is the CPS must have been on its way out before I bought the car because its now pulling like a train. When I got the car back I hit the motorway and pressed the loud peddle 'move over Mellow Yellow is coming through'. I'm well chuffed. Now if I'd have visited a $tealers instead of an indy then they'd have had my leg up for O2 sensors, Vanos units and anything else they fancy charging me for. I can't wait to go out for a run this weekend now were at full power. (I must remember my speed camera detector)
Were here for a good time not a long time.....
Let me drive Harry. I won't make a fool out of you
Turn three is really threacherous..Whether its hot or cold, it gets as slick as a button. Before you know it, you'll slick and slide and slam yourself into the wall
Loose is fast and on the edge, you're out of control
If you think its luck, let's do it again
Tim tells me you've been running open wheels
I'll give you an engine, low to the ground. An extra big oil pan to cut the wind from underneath you. A fuelline that will hold an extra gallon of gas, shave half an inch off you and shape you like a bullet. And once you're painted and weighed, you'll be ready to go out on that racetrack, you here me, you will be perfect.
Methanol...mechanical fuel injection 1100 lbs....140mph at the end of the straights... Oh and then you turn left and do it all over again..... 5/8 mile & 20 second lap times.....Quicker than a Nextel car on the same size track
... Then we'll let that teeth whitening, couch jumping, scientology raving nutter loose with you and you'll come back without any straight panels
okay... so tom cruise is my favourite actor.. hahaha
1999 Imola Red M5. Extended Caramel Interior Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
__________________ ///M5HD91-229- |Eibach|Koni|Porsche Brembo for looking through the windscreen ///M535iDC71-181-
|H&R|Bilstein|Sparco for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz for fun C1 2.5 1531-184-
|D-1 cage|full race spec for looking at chequered flags
