DIY Header install guide? - BMW M5 Forum and M6 Forums
Old 15th February 2007, 09:15   #1
Todd
Todd's Avatar
Garage: E46 Individual M3 & 2003 M5
Does anybody have a link to a DIY guide for header install?
Thanks,
Todd
Todd is offline   Reply With Quote
Old 15th February 2007, 15:05   #2
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
I have not seen one... maybe most people just have a shop do the work. I will be starting my installation in a few weeks or so and will take pictures and if time allows, do the write up. The SS header company does not have much.
If you find something, please post.
Thanks,
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline   Reply With Quote
Old 15th February 2007, 15:44   #3
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Thanks,
Todd
No link, but from my installer, I believe entire exhaust was dropped. Let side motor mounts need to be loosened to get stock manifold off. Tough to get the SS springs on (if not SS, this won't apply). He did it over two days and it wasn't particularly difficult, but there were a couple of times it paid to have a second pair of hands.
You might check with the guys at D/A, Evosport, or Jon@Mshop.
Old 16th February 2007, 07:41   #4
shadowman
shadowman's Avatar
Garage: Z8
As has been shared; rather straight forward.
The OEM exhaust is one piece as such it requires two in order to comfortably remove it.
Once out if using the OEM cats you will need to cut them at the "PROPER" place for the connecting pipes to fit well; and they fit very well if cut properly. Once cut “DO NOT” bench weld the pieces but rather install the headers; then the back half of the exhaust and then fit the connecting pipes into place last and then weld then with the assembly in place. The connecting pipe needs to be welded first around the inside tube at the cat after which the collar is slid into place and it too is welded creating the final seal. Once completed (if Tig welded) it will appear as OEM. Furthermore once the welding as described above is completed you will be done except for reinstalling the O2 sensors and misc. soft items under the gal.
Now as for removing the OEM exhaust manifolds;
The right side is NBD
However; removing the left side exhaust manifold requires removing the solo 16mm motor mount nut and then raise the left side of the motor about an inch; it is not rocket science here when up enough the manifold will slid right out. A word of caution; if you have a strut brace remove it in advance, disconnect the battery, and leave the hood open
Now once everything is out the installing of the 8 tubes can be awkward but not terrible. Once all 4 tubes on a given side are in place with the nuts snug but not tight we always slide the collector spring plate into place prior to final tightening so as to verify alignment of the tubes. Then prior to installing the collector we put some anti-seize on the tubes and within the collected and then with a piece of hardwood and a hammer simply tap it into place. Once in place the springs (likely because we have done so many are not a big deal). We have a couple bent tipped punches that fit into the slots and wholla…..
Hopefully this has helped a bit
The greatest thing I would say is “RELAX”, enjoy the process and even if you get to a point that you want to pull your hair out …don’t…..simply walk away for a few minutes and then re-approach the project knowing full well that “MANY” before you have completed it and that once completed she will breath so much better; to the tune of approximately 35 HP which you will feel from day one.
Takes care
Shadowman
shadowman is offline   Reply With Quote
The Following User Says Thank You to shadowman For This Useful Post:
kevinf (24th April 2011)
Old 16th February 2007, 08:41   #5
code7rpd
Garage: BMW 540i Anthracite
Great write up Shadowman. Do you happen to know what kind of horsepower increase SS headers with stock cats would provide an e39 540? Is the SS header the same for the e39 M5 and 540?
code7rpd is offline   Reply With Quote
Old 16th February 2007, 09:01   #6
shadowman
shadowman's Avatar
Garage: Z8
Thank you and you are most welcome.
Certainly I missed something however I think I hit most of the key points; however as I have always shared; if one feels like their back is against the wall by all means ask and if I see the smoke signal I will do my best to help.
The HP increase remains very similar whether using small metal bed cats or the OEM cats. Now here is the catch; a couple years ago the viability of integrating the OEM cats was sound largely because of the associated cost however as the gals have increased in miles so has the need to replace OEM cats become more common at which point I suggest folks to consider alternatives.
I will also share that all aftermarket cats are not the same even though through solicitation one is often times lead to believe that they are. Remember that I always share that "PT BARNUM" is alive and well.
Now as for the 540 and the M5 sharing the same headers; I must qualify this answer by sharing that I have never installed a set on a 540 however it remains my understanding that they are the same. Please call our to confirm this or they may in fact chime in as well.
Regardless the power to be gained as the result of headers on the 540 will also be appreciated even though a bit lower in gross numbers when compared to the M5 because the baseline HP of a 540 is lower.
I hope this helps
Regards
Shadowman
Old 16th February 2007, 12:26   #7
mr_bock
mr_bock's Avatar
Thanks Shadowman for sharing your knowledge and tips!!!!!! This is exactly the kind of stuff that only comes from experience that will help alot.
Very much appreciated!!!!!!!!!!!!!!!!!!!!!!!
Old 16th February 2007, 12:38   #8
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
Very true. Have a look at my Supersprint report here:
My Supersprint factory visit via Monaco and Ferrari: a 6000 km trip (4000 miles)
Superspritn and it's springs makes it possible to install the system without moving the engine: with other systems that migh tbe possible. Installation ivolves removing the steerring comumn and more, at Supersprit faciltiies it took over one day.
Takes care
Shadowman
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
Old 16th February 2007, 12:59   #9
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Excellent write up Mr. Shadowman. Thank you!
FYI, I am having my SuperSprint headers and connecting pipes installed right now by an installer. He doesnt have any experience on this yet so it is taking him a little time.
According to him, my stock headers are out and the SS headers are already in. He said the stock headers were a pain to remove.
He is a little puzzled on how to properly install the connecting pipes though. Your input should help him a lot so I will forward the info to him as he expects to finish the install job today.
Jon@mShop helped me out too. Lots of very helpful people on this board.
Many thanks again for sharing all the info. I will take photos of finished installation and share it with all of you.
I expect to get my beast back tomorrow, then reload Powerchip 93.
I cant wait to hear the better sound the SS will add to my Tubi Rumore Plus exhaust, and feel the butt o meter improvement.
Take care
Shadowman
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
Old 16th February 2007, 17:37   #10
Jon@TheMShop
Representative for themshop.com, m5board.com Sponsor
Garage: '98 M3 and '07 335i sedan
Not sure how much the power gain will be on the 540i (maybe more than 25hp) but the Supersprint Headers are the same for the M5 and 540i. It is highly recommended to get software though. Contact Shadowman if he has software available for the E39 540i header setup.
Jon C.
Jon@TheMShop is offline   Reply With Quote
SS Header Install - gas leaks? Atrain E39 M5 and E52 Z8 Discussion 26 16th December 2007 21:00
DIY DEPO headlight install? REDL1NE M5 E39 M5 and E52 Z8 Discussion 9 23rd March 2007 19:38
Supersprint Header & SS Cats Install Underway w/ Pictures! KeithTa E60 M5 and E61 M5 Touring Discussion 3 1st September 2006 16:06
Recent SS header install gsfent E39 M5 and E52 Z8 Discussion 9 15th December 2004 19:28
Header install question. phillym5 E39 M5 and E52 Z8 Discussion 11 10th March 2004 10:14
