Originally Posted by iMac
Tried to spray belts and rollers with wd40 , did not help
Yes , it appears ONLY when engine is cold and around 3000rpm ONLY
Spray belts with WD40? Wouldn't that make them slip? Try hairspray if you want to make them sticky.
How about a belt tensioner? Aren't there bearings inside that can wear?
When warmed up, perhaps there is just enough lube to stop the noise. Best to warm the car, and have mech use a stethoscope while someone revs to 3000 (and I would put on lift with wheels off the ground just to play it safe) to locate where the sound is coming from.
