Old 15th February 2007, 08:02   #1
TMRM5
TMRM5's Avatar
Garage: 2003 M5 Black on Black
UUC SSK problem
I had my UUC installed today and when i picked up my car it is really hard to get the car to go into 2nd gear. I dont understand why. There isnt anything to adjust on this thing. All other gears engage fine, but 2nd is HARD to get in or grinds. Anyone else have this issue? My installed did a B&M and the UUC and he said not only did the b&M take less time to install and cost less, it felt like it shifted better. What gives?
Powerchipped, Custom Magnaflow Exhuast, K&N drop in filters, UUC + DSSR, Image Dynamics Speakers and subs, Zapco Amps, Angel I bright
www.tmrmzine.com/335
www.tmrmzine.com/m5 <-- Sold I miss her :-(
TMRM5 is offline
Old 15th February 2007, 08:54   #2
drallen
drallen's Avatar
Garage: M5 Jet Black
Did you also have the DSSR installed?
There seems to be an issue getting into second if it was not installed in the correct way...
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Jet Black 2002 M5
drallen is offline
Old 15th February 2007, 09:11   #3
TMRM5
TMRM5's Avatar
yes the DSSR was also installed. Where did you read about the problems with not being installed corectly and 2nd gear issues?
TMRM5 is offline
Old 15th February 2007, 09:46   #4
jrlo997
jrlo997's Avatar
Garage: 2003.5 M3 Mystic Blue Metallic (Sold)
i had problems with the DSSR too. my INDE mechanic showed me it was installed correctly. ultimately, i ended up going back to the OEM selector rod.
just my opinion here, but i think the problem is in the design of the DSSR. i noticed that the DSSR is a straight piece, where as the OEM selector rod is bent just above the guibo. again, just my opinion, but i'm thinking that the fact the DSSR does not have the "bend" is why i was having problems engaging 2nd gear, i.e. there must be a design/mechanical reason for the bend.
anyway, like i said i'm back to the OEM selector rod with the UUC EVOIII SSK... shifts like butter now.
jrlo997 is offline
Old 15th February 2007, 14:42   #5
willm5ad
willm5ad's Avatar
Garage: m5 indi oxford green 2000 335i 2007
Some people have installed the DSSR the wrong way round, check if the cutout is as per the instructions.
WillM5AD
willm5ad is offline
Old 15th February 2007, 15:53   #6
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
I have the UUC SSK with out the DSSR... no problems, smooth shifts all the time. Not sure if I should/need the DSSR.
Hope you get yours sorted out!!!
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 15th February 2007, 16:23   #7
Lscman
Garage: E39
I personally installed DSSR and UUC shifter. Mine shifts like butter and I verified clearances and function before using it. I have a deep understanding about the shift linkage and tranny function, after spending a year studying shifter options before buying.
A search will provide necessary info, but I will regurgitate & summarize.
Issues like this posted on this board (relating to DSSR) have been traced to either:
1) DSSR rod mounted upside down
2) DSSR rod mounted backwards
3) Mixing DSSR with a non-UUC shifter. A shortshifter of some other brand could possibly have significantly different geometry/design that would cause the DSSR to contact the shifter frame assembly in 2nd gear.
4) buyer gets a DSSR that is not specifically designed for the E39 V8 application. This can happen if you buy off ebay or from someone who does not understand the small differences between versions. UUC sells several DSSR's and some folks assume they are the same. Some idiots assume that other DSSR's of the same length are compatible...they are not. Rely upon part#.
5) buyer gets a used or "NOS" new old stock E39 V8 DSSR that was manufactured at least 2 years ago. This can only happen if you buy used or someone selling very old stock. Variations in shifter mounting frame caused occasional interference like you describe. This resulted in a redesign over 2 years ago that made the E39 V8 DSSR machining slightly different than for other apps.
Believe me, one of these 5 problems applies to you. The difference in shape between the original rod and the DSSR is not the problem. The E39 V8 DSSR should have a substantial notch machined out of it on one end and the other end should be tapered like a cone. There are pics on this forum somewhere. I think these two characteristics are unique to the V8 application. Some other DSSR's may appear same to the untrained eye. The cone end of the DSSR goes on the shifter end & I think the notch goes downward to clear the guibo on the tranny end. My memory is fading, sorry. The conical relief on the shifter end is specifically designed to clear the aluminum shifter frame mount when the shifter is in 2nd gear. The other end is machined like the end of a hot dog, not a cone. Me thinks you do not have a cone shape on the shifter end of the DSSR due to improper install or wrong part#.
Resolve never, screw genuine.
Lscman is offline
Old 15th February 2007, 18:08   #8
jrlo997
jrlo997's Avatar
what you're saying makes sense. i bought a used one and i think my situation fits #4 or #5 above. i think i got an "old stock" part. oh well. i'm leaving well enough alone now.
TMRM5, i hope you get yours fixed. good luck!
cheers!
Jason
jrlo997 is offline
Old 15th February 2007, 23:21   #9
M5Racer
M5Racer's Avatar
Garage: BMW M5 '02
Get Dinan original - anything else is just a waste of your $$....
M5Racer is offline
Old 15th February 2007, 23:41   #10
TMRM5
TMRM5's Avatar
Well the issue has been resolved. It was a KNOWN issue with UUC and it pisses me off that they did not put it in their instructions that this issue may come up. In older cars there is a lip around the older 2001 and older cars around the shifter ball that causes the ball to hit. I called them and mentioned my problem and they knew right away. I even mentioned they should put it in their instructions and the guy laughed like yea right ha ha. Pissed me off since it ended up costing me an extra $65 to have it repaired.
In the picture with the arrorow shows the lip that the shifter was hitting and what i had to do was shave that lip off. Did that and it works fine.
What makes me mad is this company that i read about great customer service took almost a month to get my order completely properly shipped, i feel they weezled their way into not giving me the web described discount ( but i can live with that ) and now this issue. I went with this shifter because many of you guys here have it and that says something, but if i had to do it again, i would buy a rouge or a B&M. I should mention the shift knob has a rattle now also. Anyhow, that is my UUC expierience.
TMRM5 is offline
Engine vibrations at 1300-2100 rpm? Snogard E39 M5 and E52 Z8 Discussion 60 3rd May 2007 02:06
FS: UUC SSK, Kellerner Exhaust, PSS9, SS X-Pipe sycosho For Sale or Wanted 28 8th January 2007 19:53
Dinan vs. UUC SSK UltFamCar E34 M5 Discussion 8 28th March 2006 16:11
My 9 month problem with UUC and bad customer service. (case resolved) lwebb12 Off Topic Forum 49 3rd September 2005 18:40
UUC vs. Autosolutions Shortshifter tfung E39 M5 and E52 Z8 Discussion 4 1st December 2001 12:00
Page generated in 0.18737 seconds with 12 queries
