• Latest threads
    • Custom feed
      • Updates
        Old 14th February 2007, 05:35   #1 (permalink)
        Boss Hog
        Ride height question - 2001 M5
        Hi,
        I bought my M5 used, it's an `01.
        The rear fender lips are rolled so I'm assuming it's had some +1 size wheels at some point in its lifetime.
        I'm wondering how to tell if the car has been lowered already? Do M5s sit lower than other e39s from the factory? Because it sits lower by a little bit compared to my 540i.
        What springs work well to lower if you want the 19" wheel look with the tight fender well gap. Not slammed, but classy and mean looking.
        Thanks!
        Boss Hog is offline
        Old 16th February 2007, 05:50   #2 (permalink)
        wentouch
        the m5 stock does sit lower than the other e39s by almost an inch (something like .9 cm).
        other than getting complete coilovers, i believe typically only front springs are offered for the m5 for lowering.
        just have the car raised, remove a wheel and check whether the springs are cut.
        wentouch is offline
        Old 16th February 2007, 06:35   #3 (permalink)
        Beamer_usa
        Beamer_usa's Avatar
        How is the E39 M5's suspension different from that of a regular 5 Series?
        The suspension of the E39 M5 shares its basic aluminum-intensive MacPherson strut/multi-link design with that of the V8-powered E39 5 Series models but incorporates several specific changes from BMW M:
        -Specific spring rates with reduced spring height (0.9-inches shorter than standard E39 springs, 0.1-inches shorter than M-Technic E39 springs)
        -Specific shock valving
        -Thicker anti-roll bars front and rear
        -Polyurethane auxiliary springs in place of rubber units
        -Steel balljoints in place of rubber rear suspension bushings
        2000 Silvr(354)/Blk(M1SW)
        Dinan Cans
        PC 93
        Beamer_usa is offline
        Old 16th February 2007, 06:52   #4 (permalink)
        VetteRacer
        VetteRacer's Avatar
        Send a message via ICQ to VetteRacer Send a message via AIM to VetteRacer Send a message via Yahoo to VetteRacer
        Just FYI, 2.54cm in an inch...
        VetteRacer is offline
        Old 16th February 2007, 16:53   #5 (permalink)
        Need4Spd
        Need4Spd's Avatar
        If you want to lower your car w/o it being really slammed, you can get a set of H&R front springs. Drops by about an inch from stock.
        Need4Spd
        Need4Spd is offline
        Old 16th February 2007, 20:24   #6 (permalink)
        cramer
        cramer's Avatar
        The rear fender lips are "rolled" at the top from the factory.
        Chris
        cramer is offline
        Forum Jump
        M5 / M6 Comparison Filthy Monkey E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 55 22nd November 2007 19:12
        M5 / M6 Comparison Filthy Monkey E60 M5 and E61 M5 Touring Discussion 54 22nd December 2005 11:51
        New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 10:45
        Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 03:29
        Clear light question for 2001 M5 E39 M5 and E52 Z8 Discussion 0 2nd October 2001 07:34
        Page generated in 0.37651 seconds with 11 queries
