• Latest threads
    • Custom feed
      • Updates
        Old 14th February 2007, 00:51   #1 (permalink)
        Emmasis
        Emmasis's Avatar
        Front and rear sways
        I just sold my e46 M3 with coilovers, urethane bushings and sways, I don't want that kind of ride on the M5 but I want to get rid of the body roll.
        What are everyones favs?
        I will just do sways and the beefed up rear sway link.
        Please don't post Dinan, I will NOT spend that kind of money for their average product.....Or Schnitzer
        Thanks guys
        Emmasis is offline
        Old 14th February 2007, 02:08   #2 (permalink)
        mottati
        mottati's Avatar
        Thanks guys
        I guess you've answered your own question. Only other sway bar i know of is eibach.
        Engine:
        Suspension:
        Interior/Misc:
        mottati is offline
        Old 14th February 2007, 02:20   #3 (permalink)
        warhaven
        warhaven's Avatar
        Hmm. $200 for Dinan... but I guess you've decided to equip your top of the line Genrman engineered Sport Sedan with cheap parts... okay your call. You can always have your local Honda shop just tig weld a piece of steel between your shock towers.
        Good luck!
        warhaven is offline
        Old 14th February 2007, 02:40   #4 (permalink)
        Emmasis
        Emmasis's Avatar
        Good luck!
        I am willing to spend more than $200 on sway bars, I am just not super impressed with what Dinan had to offer for the M3
        There are no others who make sways?
        Ground control for example.......
        Like this one
        Emmasis is offline
        Old 14th February 2007, 03:54   #5 (permalink)
        derheilige82
        derheilige82's Avatar
        Send a message via MSN to derheilige82
        If I could get a Dinan front sway bar for 200 I would, my dinan dealer is asking 499CDN. Anyways, this is indentical in design and shape (except for the CF inserts) and the metal is the same....ie the same bloody part as dinan!
        http://www.cosmoracing.com/search.asp?searchstring=e39+bar
        derheilige82 is offline
        Old 14th February 2007, 04:13   #6 (permalink)
        heykman
        heykman's Avatar
        Wrong on both accounts...these are strut braces and not sway bars, big difference. And they are not the same...
        2001 M5 Carbon Black
        Bone Stock for now...
        heykman is offline
        Old 14th February 2007, 04:52   #7 (permalink)
        derheilige82
        Really?
        Ok, so enlighten me...explain the differences between the two designs and the stress/strain profiles of one vs. the other.
        Old 14th February 2007, 05:12   #8 (permalink)
        M55555
        M55555's Avatar
        Both parts are totally different. Sway bars are not the same as strut bars. If you compare your link to the one Emmasis posted, you will notice how both products are different. Sway bars are below the vehicle, and strut bars are in the engine and trunk compartments. Both aide in suspension, however, sway bars play a bigger role in eliminating body roll when compared independently. Now, with both setups combined of course it would be better than both individually, but sway bars are more useful than strut bars are. For more details feel free to search as the topic of sway bars and strut bars have been discussed previously many times.
        2001 Carbon Black ///M5
        BBS RC 18x8.5F/18x10R | Bilstein PSS9 Coilovers | ESS Software | Magnaflow 14816 | E60 545i SSK | 3000K HID Fogs
        M55555 is offline
        Old 14th February 2007, 05:53   #9 (permalink)
        derheilige82
        uh oh
        [quote=M55555]Both parts are totally different. Sway bars are not the same as strut bars. If you compare your link to the one Emmasis posted, you will notice how both quote]
        WHOOOOOOOPS....in my defense I am at work now until midnight and I have a tendency to ignore links sometimes. My apologies heykman. I've had the my eyes on the STRUT bars for a while now so my brain was stuck on that.
        Old 14th February 2007, 05:58   #10 (permalink)
        mottati
        mottati's Avatar
        wow that is the most generic looking strut brace i've ever seen! In The pic of the rear shock tower brace, it doesn't even look like it bolts to the strut towers... Yeah, that looks identical to dinan's.....
        Sway bars are torsional springs, to reduce or controll body roll.
        Strut braces tie the strut/shock towers together, stiffening the body. Mostly eye candy, unless you're running R compound tires and or tracking the car.
        Engine:
        Suspension:
        Interior/Misc:
        mottati is offline
        Old 14th February 2007, 06:02   #11 (permalink)
        derheilige82
        Yah anyways, the design is the same if you can't see that, not my fault.
        BUT Sparco makes what you are looking for, you have to call them to get the details; it's not posted on their website. 1-800-224-RACE
