• Latest threads
    • Custom feed
      • Updates
        Old 13th February 2007, 15:31   #1 (permalink)
        PowerM
        Raise the idle
        Based in my previous thread without replys... I think is better to change the question for this...
        Someone knows which is the best manner (or simply the manner) to raise 200 rpms the idle of the E39 M5???
        The car is an Euro model, this is because talking with Sean (D/A) said that the ECUs are diferent (I do not know in what things...)
        Cheers,
        Felix
        PowerM is offline
        Old 13th February 2007, 15:54   #2 (permalink)
        MGZ
        MGZ's Avatar
        Why? My car idles at abt 600rpms when it's warm. Why do you want to raise it??
        MGZ is offline
        Old 13th February 2007, 16:01   #3 (permalink)
        PowerM
        Because I have a lightweight flywheel and when revin' down fast the car can not maintain the idle and stops...
        I need to raise from aprox. 600 rpm to aprox 800-900 rpm
        Cheers,
        Felix
        PowerM is offline
        Old 13th February 2007, 16:33   #4 (permalink)
        MGZ
        MGZ's Avatar
        I see. Will follow this thread closely.
        MGZ is offline
        Old 13th February 2007, 16:42   #5 (permalink)
        Need4Spd
        Need4Spd's Avatar
        The only way I know to raise the idle is to reprogram the ECU. The idle speed is controlled bya software feedback circuit, so making mechanical changes will simply force the software to compensate back to 600 rpm, until it can no longer do so. I suppose it's theoretically possible to drill a hole in the idle speed compensator if there is one (idle speed is often controlled by a small compensator valve, but not all cars work the same way) but I don't know enough about that for this particular car to have any concrete suggestions. Drilling the hole would be tricky in any event b/c it would be hard to know how big to make the hole w/o experimenting, and possibly ruining a few compensators in the process. Isn't anyone, like Powerchips, able to reprogram your ECU?
        Need4Spd
        Need4Spd is offline
        Old 13th February 2007, 16:44   #6 (permalink)
        m5admirer
        m5admirer's Avatar
        As far as I know the only way to do this is by software. Companies like PowerChip can do it for you when upgrade to their software.
        Rob.
        m5admirer is offline
        Old 13th February 2007, 16:50   #7 (permalink)
        PowerM
        Powerchip and other brands based in the US are not capable to resolve the problem in Euro models...
        Other brands from EU can not do it except one in the UK but needs to have the car and I am living in Spain so very expensive...
        Thanks for the idea of the hole... If I do not ear something better I will try with this but I have time to find a better option
        Cheers,
        Felix
        PowerM is offline
        Old 13th February 2007, 17:00   #8 (permalink)
        PowerM
        I am looking about these terms in the www.realoem.com page...
        Using IDLE as a word string to find... the results was:
        Part 13411733090 (T-SHAPE IDLE REGULATING VALVE)... I do not know if this valve do the same work as I need...
        T-SHAPE IDLE REGULATING VALVE 1 03/1999 13411733090
        Cheers,Felix
        PowerM is offline
        Old 13th February 2007, 17:13   #9 (permalink)
        Frits
        Frits's Avatar
        Are there no decent chip-tuners located in Spain? I mean, guys that can adapt software themselves, and not just copy some values from another company?
        I got my M5 chipped, and there were definitally values I could choose for myself, e.g. rev limiter, speed limiter etc. I'm 100% sure the guy that chipped my car (http://www.power-plus.be) can fix your idle problem.
        Frits is offline
        Old 13th February 2007, 17:22   #10 (permalink)
        PowerM
        Thanks Frits, Can you give me an aproximately price of the ECU you are using...
        Mine is an UPSOLUTE ECU, I talk yesterday with they and said it would be posible to do this putting more load, but this affect to all of the rpm range not only in the idle!
        Cheers,
        Felix
        PowerM is offline
        Old 13th February 2007, 17:27   #11 (permalink)
        Frits
        Frits's Avatar
        I payed a little over €500 for the software if I remember correctly. Prices are on the site, I payed less than the advertised price.
        Frits is offline
        Old 13th February 2007, 17:30   #12 (permalink)
        PowerM
        Ummmmm nice price!!!! but the problem is I am in Spain and these guys are in Belgium... and I can not go to there with my car...
        Thanks a lot!!!
        Cheers,
        Felix
        PowerM is offline
        Old 13th February 2007, 17:32   #13 (permalink)
        Frits
        Frits's Avatar
        You could send them your ECU, they adapt it, and send it back. Ofcourse, you won't be able to drive your car in the meantime...
        Frits is offline
