Battery 100ah or original 110ah ? - BMW M5 Forum and M6 Forums
Old 16th January 2007, 17:27   #1
iMac
Garage: M5 red
new bmw battery 110ah cost 300$
varta or bosch 100ah cost 140$ (both don't make 110ah)
is it ok to install 100ah ???
cheers
iMac is offline   Reply With Quote
Old 16th January 2007, 17:34   #2
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
Should be fine, it's just that with 100ah you will shorten (by a little bit) the time that you can leave the key on w/o the engine running.
E55AMG2 is offline   Reply With Quote
Old 16th January 2007, 18:03   #3
1mpowerme
1mpowerme's Avatar
Garage: 2000 Carbon Black M5
Sales Feedback: (7)
I would compare the CCA ratings as well and be sure they are close. The initial start up is what you should be most concerned with and the load put on the battery. If I remember right, the BMW battery is around 650 CCA.
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Bilstein PSS9 Suspention
- Dinan F&R Tower Struts
- Navigation Upgrade to MKIV Computer and 16:9 Widescreen
- Headlight Upgrade to Hella Headlights w/Angel Eyes and 6000K HIDs
- Fog Light Upgrade with 6000K HIDs
- Tail Light Upgrade with Hella Celis Tail Lights
- BBS RGR Diamondblack Wheels
- Tubi Exhaust
- UUC Short Shifter
- Black Kidney Grills
- Carbon Fiber Roundels on Wheels, Hood and Trunk
1mpowerme is offline   Reply With Quote
Old 16th January 2007, 18:52   #4
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
I have a 100 Ah battery in my car. Zero problems so far (knock-on-wood).
The 100 Ah battery is probably slightly smaller. You will need to secure the battery with something (preferrably not too flammable) to keep it from sliding sideways when you corner hard.
Also you want to make sure the vent hose connector is on the same side as the BMW branded battery, so you can run the vent hose the normal way to the tiny hole at the bottom of the left side of the battery compartment.
David
DavidS is offline   Reply With Quote
Car won't start - dead battery again? C43///M5 E39 M5 and E52 Z8 Discussion 40 22nd November 2008 21:00
Interstate MTP-93 Replacement Battery - check your installation greg E39 M5 and E52 Z8 Discussion 2 9th September 2006 00:10
Weak battery kalvin E39 M5 and E52 Z8 Discussion 43 15th December 2005 19:44
Low Battery after standing idle? Loz E39 M5 and E52 Z8 Discussion 5 26th February 2002 20:10
