Old 13th January 2007, 22:50   #1
whatheheck
whatheheck's Avatar
Garage: 2006 M6 Indianapolis red
Sales Feedback: (3)
Interior / dome lights LED upgrade.
So here comes another LED upgrade.
The stock bulb is too dim for most of us. The Xenon is an improvement but still not good enough.
I upraded to the plug and play festoon LED bulbs but still not bright enough for me.
So, now, autolumination has new Superstar Superbright festoon LED's. The same bulbs I used on Trunk and footwell LED bulb uprade.
One LED is still not bright enough for me so I put two of them side by side.
Summary: Now I am happy! Please see below:
So, just got done upgrading the dome/interior lights to two side by side Superstar LED's. Here are some info and photos for sharing.
Important notes:
1) LED's have polarity so make sure you mark the LED's with red for positive and black for negative.
2) My first solder job, I attached the wires directly to metal end caps. Due to the heat of solder, the LED wire inside became a little lose, thus it would flicker when I move the bulbs. I dont want to deal with this issue later
so I decided to remove the metal end caps and solder it directly to the LED wire, now better connection. See solder 1 and solder 2 photo. Your choice of which solder job you want to do.
3) My tester for LED's: if you have an old 9 - 12 volt power adaptor from an old walkman, cut the end connector, strip the end wire, mark the positive and negative wires and you can now use this as an LED bulb tester. See photo named Solder & tester.
Front LED dome light:
1) Mark positive and negative, put them side by side and glue the LED bulbs together using a drop of superglue. See photos.
2) No need to attach any long wires. Just solder the wires together on the back side of the LED. Now you can install this directly to the front dome light housing. It fits perfectly.
3) To prevent the end caps from shorting inside the dome metal reflector, apply electrical tape to the back of the LED as shown.
I tell you, my interior light is the brightest & whitest it has ever been. This is bright & white! None of that incandescent yellow bulb effect.
Another worthy LED light upgrade for our beast.
Hope this DIY instructions will help some of you that is thinking of doing this upgrade.
Dan
Interior / dome lights LED upgrade.-resize-1-stock.jpg.jpg
Interior / dome lights LED upgrade.-resize-2-xenon.jpg.jpg
Interior / dome lights LED upgrade.-resize-3-superstar-led.jpg.jpg
Interior / dome lights LED upgrade.-resize-4-bulbs.jpg.jpg
Interior / dome lights LED upgrade.-resize-5-rear-1.jpg.jpg
Interior / dome lights LED upgrade.-resize-6-rear-2.jpg.jpg
Interior / dome lights LED upgrade.-resize-7-solder-1.jpg.jpg
Interior / dome lights LED upgrade.-resize-8-solder-2.jpg.jpg
Interior / dome lights LED upgrade.-resize-9-inside.jpg.jpg
Interior / dome lights LED upgrade.-resize-10-solder-board.jpg.jpg
Interior / dome lights LED upgrade.-resize-11-installed-5.jpg.jpg
Interior / dome lights LED upgrade.-resize-12-finish-1.jpg.jpg
Interior / dome lights LED upgrade.-resize-14-finish-2.jpg.jpg
Interior / dome lights LED upgrade.-resize-15-finish-3.jpg.jpg
Interior / dome lights LED upgrade.-resize-16-finish-4.jpg.jpg
Interior / dome lights LED upgrade.-resize-17-finish-5.jpg.jpg
Interior / dome lights LED upgrade.-resize-18-finish-6.jpg.jpg
Interior / dome lights LED upgrade.-resize-19-solder-tester.jpg.jpg tester.jpg.JPG
Interior / dome lights LED upgrade.-resize-1-xenon.jpg.jpg
Interior / dome lights LED upgrade.-resize-2-solder-2-together.jpg.jpg
Interior / dome lights LED upgrade.-resize-3-front-side.kpg.jpg
Interior / dome lights LED upgrade.-resize-4-back-side.jpg.jpg
Interior / dome lights LED upgrade.-resize-5-installed.jpg.jpg
Interior / dome lights LED upgrade.-resize-6-installed.jpg.jpg
Interior / dome lights LED upgrade.-resize-7-works-good.jpg.jpg
Interior / dome lights LED upgrade.-resize-8-lots-leds.jpg.jpg
Dan
Supersprint Headers, Tubi Rumore Plus exhaust, Dinan CAI, Defi Heads Up Display, Strong Strut front anti-sway bar, Powerchip 93 S/W, Euro Arm rest, Fikse Profil 5S Rims; Goodyear Eagle F1 GS-D3, Polk Audio Tweeters, Boston Acoustic Speakers, Integrated 60gig Video Ipod, HiDef DICE Radio iPod interface, Icelink, Rouge Engineering Short shifter, StopTech Big Brake Kit, TC Design rear sway bar brackets, HID 8000k fog lamps, 8000K low beams, Euro clear corner HID headlamps, Mark IV Nav, Lamin X films, Predator ICE LED AE, Valentine 1, M20 Blinder Anti Laser, TEC cup holder, All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, Hella TC-400 Tire Pressure Monitor System, etc.
whatheheck is offline
Old 13th January 2007, 23:39   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
wow that is bright!
So does the 'fade out' of the interior lights still function normally with leds?
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 13th January 2007, 23:41   #3
Vossen10
Vossen10's Avatar
Garage: M5
You're all about the LEDs lately!
Looks great (as do your previous LED upgrades). Thanks for the DIY writeup!
Dinan M5
335i Coupe
Vossen10 is offline
Old 14th January 2007, 00:10   #4
whatheheck
whatheheck's Avatar
Sales Feedback: (3)
Hi Mike. Good question.
LED's behave differently than incandescent bulbs. Similar to LED brake lights you see nowadays like on the M3, LED's are almost instant on and instant off. So the effects of the interior bulbs after the LED upgrade are now almost instant on, then from full bright, not a little dim, then instant off.
So if people love the dimming effect of the stock interior bulbs, they may not want to do this upgrade.
Vossen10 = thanks for the compliments.
I will post more photos tonight when its pitch dark.
Originally Posted by mottati
wow that is bright!
Dan
Old 14th January 2007, 00:13   #5
whatheheck
whatheheck's Avatar
Sales Feedback: (3)
I meant "From Full Bright, to a little dim, then instant off."
Dan
What happened to post numbers? Guztav?
Dan
Old 14th January 2007, 00:17   #6
mottati
mottati's Avatar
Dan
thanks for the info, that was what i was thinking they would do.
Look in OT, there is a thread on the post counts!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 14th January 2007, 00:33   #7
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Hey Dan-
Looks great! How does the brightness of one LED bulb compare to a xenon bulb in the dome lights? Is it much brighter? I'd like brighter but I may not want to go the soldering route. Great job.
Edwin
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
ECB is offline
Old 14th January 2007, 00:33   #8
gherardini
gherardini's Avatar
Garage: 2002 M5 Titanium Silver
Sales Feedback: (5)
Send a message via ICQ to gherardini Send a message via Yahoo to gherardini
great write up!! great pictures! i will definately be using these shortly. i like the one of the adapter having one wire tied. that's a lot easier than what i do... i usually just touch them to my tongue to see which one's live...
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Steath Auto Turn Signal Bulbs
- Predator ICE v2.1
- Xenon fog lights
- CNS Racing clutch
- TC Designs Sway Bar Brackets
'87 K75S - "Maybellene"
'00 R1100S - "Tresor!"
Sierra Vista, AZ
gherardini is offline
Old 14th January 2007, 00:55   #9
whatheheck
whatheheck's Avatar
Sales Feedback: (3)
THanks for the compliments, and great question Edwin.
Here's the progression of brightness.
Stock
Xenon
One superstar LED
Two Superstar LED's.
So to answer your question, yes, 1 superstar LED is definitely brighter than Xenon bulb, and the light is whiter too. So if you dont want to solder, just order the Superstar LED at Autolumination.com and it will be plug and play for you.
Dan
Originally Posted by ECB
Hey Dan-
Edwin
Dan
Old 14th January 2007, 00:59   #10
whatheheck
whatheheck's Avatar
Sales Feedback: (3)
You have a very good eye!
Yes, on my power adapter / LED bulb tester, the positive is the one with the wire loop. I also painted that wire with a red mark but due to the smallness of the wire, it is not very visible so the wire loop works good, easy to spot, you'll know which one is live wire.
I know some people do the tongue test, I've seen it, but it is not a pleasant experience. One day it may actually light up your eyes when your tongue touches the wire!!!
Thanks for the compliments. You will be home soon with lots of upgrades to do! But first things first - drive the beast like you stole it!
Welcome home - soon.
Dan
Dan
Installing Celis Tail Lights 1mpowerme E39 M5 and E52 Z8 Discussion 36 12th April 2009 14:55
Anyone try these LED tail lights (kind of E46 LED style) from Ebay? ATLANTA M5 E39 M5 and E52 Z8 Discussion 12 18th January 2007 07:39
Orange and Red Lights Removed w/ Software Upgrade? gbogh3 E39 M5 and E52 Z8 Discussion 2 3rd April 2006 08:30
How to install LED brake lights atomic80 M5 E39 and E60 tips & tricks 0 2nd September 2002 03:01
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 06:00
Page generated in 0.17666 seconds with 12 queries
